- Rentz, GA
I only use my bandsaws for things I can't jig into one of my other saws. Tubing, conduit, angle, channel and flat bar gets cut up in the miter saw with a carbide blade. Bigger stuff, or anything steel, goes in the Metal chopsaw with the big abrasive wheel. Sheets get cut with a Skilsaw. I work with 99% aluminum though.
The structural steel guys on my last project use metal cutting Skil-saws to cut up to 1/2" plate.
They were ripping 20ft lengths of 8" x 5/16 in half for toe kick plates.
I use my standard Milwaukee corded skilsaw to cut aluminum sheets up to 1/2" but plan to buy the M18 metal cutting one with more enclosed guarding.
the only issue holding me back is that the cordless versions typically use thinner blades that just don't hold up as well.
