2018 wave Rave
XFT LOU
1 hp./1.83lbs
Joined
Jan 17, 2006
Likes
61
St. Louis
#21
Didn’t have any issues with strength of the lower, original cross beams which are curved, but the width and subsequent bunk height of moving the bunk brackets wider caused them to be unequal height and would have required goofy bunk brackets (tall in the middle of the dip and almost nothing on the edge of the dip).
I opted to have the framework welded on top rather than modifying (chopping the curve out and welding in straight beams in their place) since it would add strength and give more mounting options. I got really lucky actually since I basically guessed at where I wanted everything welded and it turned out nearly perfect size/ spacing. I did 4 side to side beams to give more bunk mounting options and then some front to back support bars in the rear middle which are perfect for crossing individual straps over each ski rear, which also added strength between the side to side bars back there.
This gave me enough elevation to sneak the bunk brackets out wider at the same height and allowed me to sneak up and over the wheels/ fenders so it wasn’t limited to squeezing between them. I added the different style winch post in the center and made those bunks in the center higher, which allows the skis to overlap some without smashing bond rails or touching the other skis, and allows my straps to sneak down below. Again, super lucky on spacing.
I got this trailer basically for free via a package deal, so basically all I paid for was new tires ~$140, the front center winch and post ~$150 and has about $300 into material and labor for the welding. The center bunks and brackets I already had, so it was a relatively cheap experiment, under $600 not counting my time and scrap materials I already had.
My only regret is not starting with a heavier duty trailer, like a midsize ~4k# aluminum boat trailer, like for a Boston Whaler, but they are very difficult to find in aluminum, at least for a reasonable price. Having the little bit of extra length in front would be ideal, to add a 4th set of bunks sideways and put a little more weight on the tongue. I plan to have one custom built from the ground up this winter if my funds allow for it, unless I find the ideal starting candidate to modify like this one.
You (or anyone) are welcome to bring your trailer and see mine whenever and take some measurements and pictures if you want.
Here’s some more pics of it that I had on my phone already.
That a really nice 3 ski now. My new top box tube cross beams are not welded ( for flex ) i bought long bunk supports which are still attached to the lower ones. So the carpeted wood bunks sit atop the the higher supports , holding weight also.
Before this , the whole thing was gusset’ed and re welded. It can hold more than my 4 run wants to pull.
Hope your back lets you make it to wave rave .
XFT LOU
1 hp./1.83lbs
Joined
Jan 17, 2006
Likes
61
St. Louis
#29
Mister rhugo21
Jobo asked a question directed to the men and woman working to keep Wave Rave.
Our Freeride has long history of working with the township. Sharing your “FaceBook” style derogatory response on the X shows disrespect to current and previous sponsors.
This is only my 2 cents as jet skier
Joined
Aug 16, 2011
Likes
738
Hermosa Beach, CA
#30
Mister rhugo21
No, I know Brian aka Jobu well. Our group has been skeptical for a while if the proceeds from the raffle actually go where they were intended too. Those guys that “run” the raffle now don’t even bring skis Lou...also the first people packed up and out on Sunday. Don’t know how I’m showing disrespect by answering his question. Prove us right if the proceeds go where they belong...
SpaceCowboy
breaking something
Joined
Dec 17, 2010
Likes
1,039
Ypsilanti Michigan
#31
Can’t be any worse than the Daytona Freeride. That’s a straight up scam.
schicks
Karma Enforcer
Joined
May 10, 2012
Likes
226
West Michigan
#34
thanks for checking into that steve. Freeride marine use to post how much was donated after the event. I think thats why jobu was asking. I sure do appreciate the work they put into the raffle, I know I couldn't pull it off. Not only do they pull all the items together from vendors, but they also donate tons of stuff on their own dime and time. Thanks a ton!!! it doesn't go un-noticed. I'd thank you on f-book, but I don't do that shtuff.
