A Back Flippin' 550!
Joined
Nov 29, 2016
Likes
14
west mi (Muskegon)
#42
since i ran out of epoxy, why not build a beach cart... for the cost, i couldn't justify spending $700+ for one. i still have to weld on some handles, but all in i only have $150 in materials and about 8hrs of my time. made it out of 1.5"i.d. sch40 aluminum, 1" aluminum rod for the shaft, and some smaller 1.5" o.d. aluminum tubing for the handles.
Joined
Oct 26, 2014
Likes
0
Manitoba, Canada
#43
You're going in the same route I had initially planned for my build. I chopped up an SS hull, became overwhelmed that things wouldn't line up as they should (as it was my first build) and ended up buying the Rhaas pump kit. It's some impressive piece of hardware! But it looks like you know what you're doing, nice glass work!
Joined
Nov 3, 2016
Likes
34
Northern michigan
#51
Looking good you may want to shorten the throw on the steering nozzle by moving the ball in closer. Just fill and drill it a inch further in. This will give you maximum throw when steering.
Joined
May 27, 2017
Likes
2
Huntingtown Maryland
#52
Why not cut the rails off the ski, put a gas tank under where feet are and shorten the whole front of the hull? Has anyone tried this? I want a back flipping jet ski also and have a spare hull thinking about making a back flipping SJ550.
Joined
Nov 29, 2016
Likes
14
west mi (Muskegon)
#54
tons! i have been riding it for about a month now. right off the bat the ebox had to be moved. i attached it to the front of the engine and it cracked the case from the vibration. then once in the water the the stock length handle pole put me to the very back of the tray, causing the ski to want to stand up all the time.
Joined
Nov 29, 2016
Likes
14
west mi (Muskegon)
#60
So when u do the rockered nose u cut out the bond line and just strengthen up the front without it.
On the inside of the Hull I put 3 layers of s glass. On the outside I put one layer of S glass and 1 layer of carbon fiber
Sent from my SM-G955U using Tapatalk
