Crazy Joe's BAM V2 build
JetManiac
Thinking about shredding
Joined
Jun 8, 2008
Likes
3,569
orlando
#62
Glad you made it to the water. Make sure to loctite the carb linkage screws. And swap the fuel line for OEM when you can.
Joined
May 16, 2017
Likes
100
Detroit metro
#63
Good tips. I will switch the fuel line over during the long winter.
A little update, after dealing with a bad stator at about 30 minutes ride time, I finally got the ski mostly dialed in. Initially, I had a terrible lean hesitation from idle to 1/4 where the ski would actually die if I went wot from idle. I went out to about two and a half turns out on the low screw (120 pilot) and got that mostly dialed out. I upped my idle so that the ski will not stall off throttle and that helped too. I cannot seem to source pilot jets bigger than 120 for the SBN carbs. Anyone know if they make them?
I am still getting fuel dribbling down the carb from the venturi after a quick wot cut running on my stand. Pop off tested at 32 to 34 psi each carb with 2.0 n/s and gold springs. I ordered a set of 1.8 n/s and black springs to give that a go. I am also going to double up on the check valve discs as I was reading in the Mikuni tuning manual that can help with excess pressure or leaking of some sort. I don't quite understand what those check valves do.
Now that I have 2 hours on the engine, I backed my oil ratio down to 40:1 using skicraft.
I am trying to get this engine dialed in so I can grab a handful of throttle right from idle and have it pull hard. I am not quite there but getting close. Its very ride-able now. Looking forward to taking it out after work today to get more tray time.
Joined
May 16, 2017
Likes
100
Detroit metro
#64
Finally got the engine to pull hard from idle to WOT. I backed my N/S down to a 1.8 with a black spring which netted me about 26 psi pop off. I still need to tune the needles and lean it out some but it pulls nice with no hesitation now! I doubled up on the check valves in the carbs but still have fuel dribbling out the venturi after a WOT cut. It runs good so I guess it is not a concern. Just kind of wondering what actually causes this.
Also, I am officially titled and registered in Michigan!
