Custom pole bushings
Mike W
Infidel
North Florida
I guess I should of mentioned I need a set made for a 440/550. Slightly thicker than stock to take some slight side to side play out of the pole.
If you have a STP or autocad file, I can put you in touch with a machinist who has done work for me in the past, but it will be a little on the pricey side. Another option to look into is round machine shims on McMaster. You can get them in several sizes and thicknesses.
Mike W
Infidel
North Florida
I think I’m going to look into just shimming it. That will probably work out better. Thanks for the McMaster lead.
