Flush kit for WB1
Looking for a flush kit for a WB1 with Factory B pipe - dual cooling. Can I just use a Pro-Tec universal kit and splice in the line from the pump? Not much info out there and confusing at that.
I just copied the setup from a B2 with the black wye joint, have the oem/water inlet fitting right behind the hood clamp by the vents looks clean/oem and works perfect
