JetManiac/Blue 781 - backflip capable
Jcary85
Joined
Apr 29, 2016
Likes
247
Malvern pa
#21
The wax curve is overly safe. I was just comparing curves with a pump gas buddy this morning and his is very similar to mine. Tapers off from 32 just a bit past 5k but still runs a good bit of timing all the way to 6500
Joined
Feb 23, 2015
Likes
78
Chicago
#22
Im kinda in the same boat I had a 718 and that thing was and is Freaky fast and then went to a 900 and had nothing but problems and now the motor needs bottom crank and top end and if I do it probably turn it into a 1015 but I still love my baby bore. I just talk to Blue and then saw this post now you guys got me thinking of going with a 781 from Chris and Blue!
I have a Zeel TL PFP pipe Novi 48s with ported intake 148 Torrent set back pump so Blue you might have to build me a super Jetmaniacs Blue Powered 781
If you did what prop would I need I have a 10/16 cut back 3mm I believe Chris would know.
Jcary85
Joined
Apr 29, 2016
Likes
247
Malvern pa
#23
I ran a 6/12 for a bit but felt it was under propped and bent it to 7/14ish which was just right.
