Original X-2 Gen 2 build up
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
Hello,
It has been few years since I posted on the X with something that matters (at least to me) :)
Few months ago I saw on UK Ebay the an original X-2 from 2006. I knew it was unobtainium so jumped on it immediately. The seller was a super nice guy, and an aerospace engineer so I knew the ski had good chances to be in a nice condition. I got it without even seeing it in person and 8 K USD later I am the owner of a lovely "new" X2. Ski allegedly had 30 hours on it and to be honest it shows its real nice and fresh.
The ski has been repainted in original colors (white/black), camo turfed, it has a long Macc rideplate and worx intake grate. The plate is long and sometimes mekes the ski slide for many yards if I wish so, and hook up crazy if you do it right. The ski has the temp byspass and f/a's, and electric bilge installed by previous owner.
It's a blast to ride, actually never experienced such sharp handling and riding position before and I rode many skis. I say this is the best Kawasaki Jetski ever realesed if we talk 2 stroke world.
Some hours of abuse (mostly jumps beind boats) and it was clear what that thing needs: new billet hood latches (oem-pos), foot straps and a hi rise fat bar setup - which were installed few days ago. Whoaaaa - what a difference - Accel fatbars with 160mm height + 30mm riser/adapter from 222mm to 286mm and fresh set of ODI's changed the riding position and handling dramatically. From a pure carver this thing became a water supermoto/MX/ wake jumper in one, the footstraps greatly help to manouver the ski in the air. One thing which the Gen2 is know for is the nose heaviness. I must say yeah - that reults in being completely and constantly bashed in the face with either spray or just buckets of water - it keeps you sober that's for sure but boy...... so I will move back the accel riser/adapter - as I read somewhere that in Japan they move the steering stem backwards in order to lift up that heavy nose - even an inch is supposed to make a big difference - we will see and report. I bet a nice set of long sponsons would help that, biut not sure how that will behave if I start jumping bigger wakes - any input from anybody on this?
Anyways I started ordering some parts and willing ot also do as many "free mods" as possible as I sold my both kidneys to get the ski :)
General plan:
1. All around ski with freeride inclination, reliablity, easy of usage, little maintenance as possible.
2. Make it look nice with IPD graphics kit
3. Correct factory flaws
4. Increase performance (similar to lites class setup)
Shopping list:
1. RRP adjustable hood latches - bought
2. Lites class jetting/spring kit - from SXR.com - supposedly better performance - bought
3. Blowsion green vacate valve - waiting for delivery
4. Blowsion FS cone - waiting for delivery
5. IPD kit and super cool fuel cap (fueled by haters lol)
6. Primer kit - not sure if to go for it, ski starts with a touch of a button, and taking out the chokes makes the carbs meter worse
7. Additional bilge pump
8. Pump area - I'd love to try out the TBM/RD pump stuffer they are expensive though.
9. Bore the nozzle, find extended nozzle - the ski could use of some better turning radius - anybody has any advice here?
10. OEM cooling of the exhaust- I'm puzzled here, on one hand I know it's definitely getting too much water, on the other I know we need some pressure insode the whole system - please let me know what is best on such setup as above - I do not wish or need to run dual cooling - water here is always relatively cool...
11. Should I go for increased compression - if so, in order to gain bottom/midrange - should I use a very low base gasket (to change the porting a bit) or just shave off the head a bit? If so what is gas pump safe (our max RON is like 93 here).
Also if you have any parts that could be useful in this build I will gladly consider! I'm cheap though! :)
Best to the X and it's members!
PICS ARE COMING
Andrew
UT
Man I'm super jealous of this! I have no experience on a gen 2 hull but on everything i have ridden sponsons made a huge difference in keeping the nose up, by far my favorite handling mod on any hull. It will definitely help jumping wakes too as they will help push the nose up rather than cut through the wake. I loved my Prowatercraft racing sponsons on my sj. But i also can't blame you if you don't wanna drill holes all down the side!
Polish jet pilot
Warsaw, Poland
I drilled footstraps already :)) So I could get over the idea of doing more holes to bottom deck.. Any views on short vs long ones?
Any SXR / Kawi experts still left here to tell me about that water routing on the 800 with oem pipe? Pretty please
Polish jet pilot
Warsaw, Poland
Small update. I got my RRP latches, my blowsion 1 way valve for oem drain, I took some pics of the steering setup and foot straps. Way different ski, and for the sort of riding this is intended for - perfect light mods.. more ot come as the ski is being ridden and tested. This week I should get a tech hooked up and see what's up with the RPM's. Maybe the IPD kit will also be here.. good days...
Polish jet pilot
Warsaw, Poland
Who is dealing with SATO Engineering in the US? Or Europe? I see some nice small things that would be nice - carbon fiber steering cover, dash kob delete plates etc... Also, wanted to ask you about this:
Is anybody in the know whether turning the drop nozzle into a trim system is possibe:
https://www.ebay.com/itm/KAWASAKI-J...rentrq:aa5291cb16c0aadcc7867a9efffe9849|iid:1
or should I not bother - I do want to have a larger throw and benefit from the larger diameter of the exit...
Polish jet pilot
Warsaw, Poland
"I see a forest of helpful hands" :)
In any case build update: I got my IPD graphics kit - excellent quality, vibrant colors, great material - will start putting it on friday possibly. I also got a hour/tacho/service interval meter very similar ot tiny tach, but for MUCH less - actually the price is so good that even with shipping to US this would be a great deal for y'all.
I got aos the very cool labled gas cap from IPD and my Blowsion FS cone. All these parts will go on the ski soon, and i will report immediately on progress and effects.
Polish jet pilot
Warsaw, Poland
So I am done with applying graphics - to be honest, I expected slightly more for 300 bucks - what you see on their websites and wat you get is different - on the website you get only graphics laid over a model, in real life the fit / looks becomes different due to installation - I 've seen better....
Blowsion cone installed - to be honest I do feel a slight difference over long stock one. Next step is drilling the nozzle and checking again. I will go straight to 81mm. I also ground a bit the sides of the steering nozzle and got a few mm more out of it and it shows....
I also checked and definitely have no charging in the ski - not sure whether this is a malfunction or maybe somebody in the past got ridd off the magnets?? If malfunction what goes? Stator or voltage regulator?? I'd prefere the latter for obvious reasons....
The tach/hr meter installed instead of the choke knob, what a joy to find out that it's not working once installed --- @#$%
