jetskier760
superjet760
- Rockford/GR
HI, wondering if anyone can help with timing question...here is a list of what is on my superjet...760 62T motor bored to 95.5mm, stock porting, MSD ignition enhancer, MSD wires, type 9 dry pipe, 210 psi compression, riva girdled head, dual 44 carbs, reed spacer, delta force 3 reeds and other non motor stuff.
I am running BR9 plugs with the stator set at -4 degrees. It seems happy but i would like to know for sure what to set the stator at.
From what i read on the web it sounds like you find top dead center and using a degree wheel you find out when the pistons cover the ports on the upstroke and the leftover degrees is you max timing. Does this sound right?
Any help is appreciated.
Thanks, Dan
Thanks, Dan
