I got an sxr 800 with a brand new versi plug scupper in the drain plug hole. I replaced the rubber scupper in case it was the problem. This aint leaking.
When ski engine is not running and ski is sitting in water there is water coming out of the drainage hole on the left side orientation facing forward on ski. I can check plug is sealed and it is.
If i put ski on trailer and out of water. If i fill ski with water only a few inches so not reaching exhaust exit and hold versi plug shut there is water coming out the exhaust.
Conclusion some how drain plug tube and exhaust tube are sending water to eachother under the tray.
If i stick my finger down drain plug it feels like rubber behind the fibreglass firewall.
Anyone seen this. Anyone know how to fix.
I dont want to block scupper.
