2015 xfs glass Rickter scupper started either sticking shut or would stay open and about sank a few times on the lake. decided to purchase Thrust Innovations EZ drain 2-3/4".
first step is to remove the old scupper
remove the three allen bolts
I applied some heat to the scupper ring to loosen the factory glue.
work/pry the scupper ring off using a 1" putty knife and a large screwdriver
clean the glue up inside the tube and rough about 1" of the tube using 80 grit sandpaper for epoxy later on.
your ready to install what i call the hourglass
this end goes towards the engine compartment
using a rubber mallet, tap the hourglass into the tube, it is a press fit. Do not hit it in all the way.
