Super Jet Welding reinforcement 62t case for stroker crank
Hi, i'm italian so sorry for the bad english.
I've a 62t case trenched for +6mm stroker, but i would like to trench for +10mm stroke.
My question is if I can add aluminum TIG welded, or risk the deformation of the case?
I see that everyone is using liquid aluminum epoxy and no one brings with welding material.
I have the ability to weld TIG and it would seem like a more robust than the epoxy. Why not ??
Thanks to those who can help me and this wonderful forum.
baldwin ny
if you bolt the motor all together with a crank and all you can weld the bottom case with out warping it. i have one the someone epoxy the bottom and it all started falling off. i sand blasted all the crap off made up small plates and welded it all up . no issues.
Ohio
I would say people use epoxy due to lack of welding equipment/skills/techniques.
Clearly if you can do it it would be better that epoxy in every imaginable way.
Epoxy fails...period. And crank bearings don't like pulverized epoxy going through them!
