- swanton vermont
Full Carbon fiber rage composite works brawler
Yamaha 701 62t ADA girdled head 35cc Domes
Msd ignition
lay down pipe
rrp waterbox
Dual 38mm carbs
Cart tank
Flow control valve 144 oem pump with xmetal trim
10/16 hooker impeller New pump seal
Kv bullet adjustable pole with straight bars
Rule 500 bilge pump
Few blemishes in the gel coat but no structural damage.
Ski rips hard. Super reliable build.
LOCATION VERMONT 802-309-4325 TEXT/CALL
Msd ignition
lay down pipe
rrp waterbox
Dual 38mm carbs
Cart tank
Rule 500 bilge pump
