Freakrider
X247
- Tampa Bay area
Can someone explain how some peeps post pics full screen in threads and not as an attachment here ?
Thanks...
Thanks...
code is in manage attachments or you add it yourself ?[/QUOTE]
you were doing it right in your previous edit. you just didn't close the link with
it looks like the image attach button in the tool bar at the top won't work like it used to but it still works if you do
get rid of the spaces before and after the file location.
I am still lost ?
maybe that's because the X is hosting the pic? you could have another site hose the pic and link to it. The problem with that is you use up too much bandwidth pretty quickly and the pic isn't viewable anymore.your post # 4 is an attached pic.
get rid of the code just inside of the [img] code
I am still lost ?
get rid of the code just inside of the [img] code...d ! thanks... anybody else learn from this ?
If you ever need to see how someone did something in a post just reply with quote, it will show all of the code.post # 6 edit it worked ! thanks...
