61x Cylinder- Your cylinder sand blasted then glass bead blasted in and out, new anode installed if needed, and painted and baked on beautiful satin black finish after porting and boring.
JetManiac/Blue 'Freestyle' porting designed for low end and midrange power, but not for racing or sustained WFO use.
Fresh bore to 82, 82.5, or 83mm, chamfer/hone, cleanup decking to head and exhaust gasket surfaces, ready to install
New Pro-X or Wossner upgrade piston kits with new wrist pins, clips, and wrist pin bearings
Gaskets- new cylinder base gasket, exhaust manifold gasket, and carb base gasket included, US made quality
New Mikuni carb jets and springs for oem dual 38's or single 44/46 included
JetManiac/Blue freestyle Ported Top End Kit $879.
*optional add 89. for upgrade to Wossner pistons, more aggressive freestyle porting and modify oem sleeves for even more case to transfer flow brapp.
We can provide a clean 61x core cylinder (175.) if needed.
