N2 H2O
Previously Tbone550
- Charlotte, NC
I've decided to remodel my 550/650 conversion ski. I bought it last spring and have done a lot of work to it over the past year. I've had a lot of fun riding it and am really happy with how it runs. here's the old thread: http://www.x-h2o.com/threads/97970-My-redone-550-650 I snapped the nose off my original hull, so I will be reinforcing this one heavily. I plan to do some occasional surf riding with it. I will be mainly focusing on hull mods as I feel I have the motor and pump set up pretty well for my needs. I have a 1978 JS440 hull that I will be using. The engine bay needs to be painted and the outside of the hull is already sanded down. There is no damage to the hull and it is already set up for dual cooling. This is my first time doing major fiberglass work, so I'm sure I will need some help along the way. I have bought a mint 08 rn sj handlepole, pole pad, XMV bracket, and MSD ECWI. I will get some pics up later. Here are my plans for the hull:
Widen the tray
True the hull
Fill in the fuel fill
Completely reinforce he hull
Convert to RN SJ Pole
Relocate the exhaust outlet(haven't decided on rear or front right yet)
Modify hood(move air intake and make handholds)
Paint
Watercraft Factory Sponsons(depending on budget)
Current Motor Setup:
Kawasaki 650
Milled stock head
Small pin 750 Cases
Red Top Sbn46
Bored and Timeserted Westcoast Exhaust Manifold
650 Factory Pipe
Prok F/A
Lightened 650 stock flywheel
Mariner waterbox
650 Stator and 550 ebox w/ 650 voltage regulator
Jetworks Flow Control Valve
Widen the tray
True the hull
Paint
Kawasaki 650
Milled stock head
Small pin 750 Cases
Red Top Sbn46
650 Factory Pipe
Prok F/A
Mariner waterbox
