- 1 Mile High in Colorado
Before you read this whole thread - please realize this project was never finished. The final post is here
Interesting parts of the build are summarized below:
Nose Rocker - and Nose Related Shaping
Adding Rocker to the nose
Reinforcing the Rockered nose
Creating a smoothed nose that matches the rockers contours - Bottom - part 1
Creating a smoothed nose that matches the rockers contours - Bottom - part 2
Creating a smoothed nose that matches the rockers contours - Bottom - part 3
Building a bond rail for a reshaped rocker nose
Coming up with a badass front section to match your newly rockered hull
Finishing up the badass front section for your newly rockered hull - part 1
Finishing up the badass front section for your newly rockered hull - part 2
Bonding your new custom nose piece back to the ski
Reinforcing the Hull
Adding reinforcement to the engine bay walls
Reinforcing the gunwale area
Creating a Custom Hood
Creating a custom hood - aka the fiero Rikter look!
Finishing up the custom hood
Reinforcing your custom hood so it's not all flimsy and poop
Refoaming the Rear Deck - and Creating a Custom Rear Deck
Using XPS style foam for the rear deck - aka refoaming
Finishing up refoaming the rear deck with XPS solid foam from home depot/lowes
Fiberglassing your refoamed and reshaped rear deck
Creating Custom Tubbies for Your Custom Hull
Creating your own custom tubbies - "Bubba Tubbies" - part 1 - cutting 2" XPS foam from home depot
Creating your own custom tubbies - "Bubba Tubbies" - part 2 - Smoothing, contouring and making fiberglass templates
Creating Custom Surf Style Bond Rails
Making wide and angled/flared surf style bond rails - part 1 - creating the layup shape
Making wide and angled/flared surf style bond rails - part 2 - smoothing and contouring the profile, creating negative shape
Making wide and angled/flared surf style bond rails - part 3 - laying up the top sheets
Making wide and angled/flared surf style bond rails - part 4 - laying up the bottom sheets
Designing a Custom Handle Pole in CAD
Designing a handle pole for this beast - part 1
Designing a handle pole for this beast - part 2
Creating Deeper Chines and Truing Your Hull
Creating deeper Chines - adding shape/profile to them, aka truing the hull - Part 1
Creating deeper Chines - reinforcing them - Part 2
Creating a Custom Spark Arrestor Box with Fiberglass
Creating a homemade spare arrestor box that is low profile and fits under a custom low profile hood
The finished product from the homemade spark arrestor
Pump Tunnel Smoothing and Stuffing
Pump tunnel smoothing and stuffing - part 1
pump tunnel smoothing and stuffing - part 2
Installing Threaded Inserts for a Dakine Footstrap
Installing a Dakine foot strap in a JS/SX series footwell (and probably others)
Painting Your Custom Hull
Painting, sanding and masking the hull for primer coat
Final paint - hazard buoy yellow!
Well I got a late start on this but here it goes!
Basically I plan on building a modern ski hull on the cheap. I picked up a prime 550sx and coming off a 440 it's very fun.
In the end I'd like to have a more freestyle friendly jet ski.
Day 1 - ripped off the ugly plastic that comes stock on these things (and is slippery as hell)
In the process I got a rude surprise - a crack in the top deck. This could only lead to more work!
Day 2 - defoamed that bitch. My ski was a bit Emo so it cut itself a lot too (I gave it permission with a sawzall - this was in preparation for the new top deck I planned on putting in with lowered footwells and some adjustable footholds)
Gas tank will be internal fill with a glassed over current location. I also cut off the parascope on the hood and prepared it for the new handlepole I'm making for it by starting the contour that will fade from front to back (pictured below)
Day 3 (today) - I pulled the engine and pump and everything else that shouldn't be in there when I'm glassing and pressure washing and painting it etc. etc.
So hopefully I can keep this thread updated! I plan to have a pretty nice little ski by the time this is done, with adjustable footholds (with 1" lowered footwells), polystyrene re-foaming, tubbies, "lowered" hood, new SRC aluminum shortened pole as well as complete steering assembly, lightened flywheel (thanks to #Zero) and probably other stuff if time permits.
I don't really plan on spending a lot (sans the fiberglass, foam and resins!) of anything but time on this as I'm still on a college budget, so everything I do will have to be of the home made variety.
