I have the Magoos freestyle ported 85mm flat top cylinders with a single carb, but till now i havent got my setup to run right and dont know what this setup is capable of ecxept what iv heard from u guys:frown:
When i first put the motor together, Paul had by mistake sent me the wrong size domes (28cc) so my compression was at 150psi and the ski did not feel powerfull at all for what its got, so i thought its ok its just cuz of the low compression.
So then Paul sent me 24cc domes which i got yesterday, and i put them on and that bumped my compression up to 225PSI:bigeyes: so i put some good gas and took her down for few minutes hoping that the low power issue was due to low compression but, Nope... the difference wasnt all that great, it was just a tiny bit better... i think.
I know 225psi is way high, but today im gonna swap these domes out with some 25.5cc and that should bring my compression down to 185 to 190.
Now Paul recommends running duals on his cylinders, which i havent got around doing yet cuz i wanted to try out the single, which gets me thinking now could the single carb be the factor limiting the power and unleashing the beast? So is anyone here with magoos cylinders like mine running a single carb? If so what size and how do u like it?
Today im gonna take off the 44mm ATP carb i have on, and put on a
49mm Full Spectrum and see if itll make any difference. If so then its hopefully carb issue
Anyways thanx in advance.
