<!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--> <!--[if gte mso 9]><xml> <o:OfficeDocumentSettings> <o:AllowPNG/> </o:OfficeDocumentSettings> </xml><![endif]--> So the winter build begins...a little early but that is ok since I am limited with time I have to spare. I picked up a “fairly” unmolested SN and the plan is to make a tiny and light as possible SN.
I dub this build the “L7 Tiny Nose” or something dumb like that ...
The plan thus far:
- To shorten and rocker the front
- shorten the rear pretty much all the way back to rear pump bolts
- widen the tray
- Lower the hood
- And move the top deck forward about an inch or so
Since everyone is making these micro and circus hulls I figured I would like a tiny a$$ SuperJet so I am going to give it a whirl.
If everything turns out ok and I end up liking the results next year’s build will be to make a mold of the hull then do a carbon layup, but that is just dream talking for now.
The candidate
The plan thus far:
- widen the tray
- Lower the hood
The candidate
