Surfriding Cold Water Gear for the Ocean - Suit - Gloves - Boot - Hood - my observations so far
In this post I am planning to write my opinions and observations on cold weather gear for stand up riding on the ocean.
I want to start by saying that I have really found the information on this site very useful as started to get interested and then really focused on Jetskis over the past year. I ride motocross and won a championship in the old dudes class for New England so I have experience with machines. I am really close to the ocean and have found some great folks to ride with so it is really a fun activity to be in the surf. I got an SXR this spring and learned to ride on it. What a great ski. What I found was in the big waves (I saw and rode in my first waves over 10ft this fall) was that the SXR was not set up for it. She just eat water when she rolled in the big waves and I had to be towed in for the first time ever. I had followed the instructions to button up the front hole and seal the lid etc – I installed a bilge pump the same night and was back out again but with no footholds and the weight of the ski it was not a happy time. So I got my first Superjet a 2004 RN and she is so good in the surf but so much harder to ride than the SXR that’s for sure. But I will leave my discussion of boats for another thread.
Here I want to talk about my efforts to keep riding all year long. I rode 8 months April to December in 2012 and I want to keep riding. It’s pretty cold here in New Hampshire with the days running in the low 20s to mid 30s. The water temperature as of this writing is 42 so it’s cold. Why would anyone want to ride in this weather?
I guess I want to keep progressing – I want more time on the ski on the water.
First – riding in the cold takes careful planning and a certain type of mentality. Riding in cold water can be very dangerous. I took the time to learn about how people die in cold water. For a very good read on cold water immersion and its dangers see SURVIVAL IN COLD WATER
available from http://www.ntsb.gov/news/events/201...scock-CBrooks-Survival-In-Cold-Water-2001.pdf don’t ride alone and use the proper gear.
As to the mentality you have to really want to be out there. It can be mentally challenging in my experience when there is a lot of snow on the ground and it is real cold and your thinking about riding on the ocean. Everyone else is riding sleds. I will get my first below freezing ride in this week and now I feel I can lay out my observations on gear for real cold weather riding so far.
Your going to want the following: dry or semi dry suit – boots – gloves – a hood – helmet – may be goggles.
Dry / semi dry suit. When the water first started getting cold in the fall I used my expensive 6/5/4 wetsuit. The main thing I found was that the suit felt much more constrictive in cold weather than in warmer. The win was not an issue as I have a mesh suit. Mesh is used to make the suit windproof. In warmer water I like the feeling of wearing my wetsuit. Once the water and air got colder my wetsuit felt like it was tiring me out.
So I started to look at dry suits. There are semi dry wetsuits that you can wear a poly suit under for extra warmth. My buddy runs one and the thing he notices is that it is pretty tight fitting – to keep the water that gets in warm and it kind of heavy and it is thick 6mm. THe seals on the semi dry suit he has are neoprene. The drysuit have a laytex seal.
My research revealed 3 types of dry suits: bag, bag with outer shell, and neoprene hybrid.
The bag type is a suit with rubber seals that keeps you dry. The suit provides no warmth and no floatation. Think of a suit you would wear whit water kayaking. An example is the dry suits by Kokatat. Guys say they are good quality but they are expensive and cut for sitting down not standing up.
http://www.kokatat.com/products/dry-suits.html
Other guys like the Lucifer suit that looks like a snowboard suit.
http://www.npsurf.com/products/drysuit/lucifer/drysuit.html
Ocean Rodeo also has a nice bag suit called the Soul:
http://www.oceanrodeo.com/products/soul
A major downside to the bags for me is that they have no inherent warmth. So you have to wear more layers. Also if the bag gets punctured you going to fill up with water pretty fast and that would be very cold.
The bag with an outer later is made by Ocean Rodeo see: http://www.oceanrodeo.com/products/surfdry.
This version is no longer available and check out the video of putting this thing on -http://www.youtube.com/watch?v=utM7NbRGF9k
The suit I purchased is the Ion Fuse. It is made for kiteboaring so it has the right cut and is windproof. It is made of neoprene so it has warmth built in. Best of all it has some flotation properties and can give you a bit of warmth if it ever got punctured.
See the suit here: http://www.ion-essentials.com/public/content/products/neoprene/wetsuits/series/fuse/fuse/
I have ridden with the suit over a dozen times and it is very good. It is loose fitting so not tiring like the wet suit was. I wear this suit underneath: Immersion Research union - http://www.immersionresearch.com/product/mens-layering/mens-union-suit/ I like it, as it has no zipper to catch inside the dry suit.
I do get wet inside the dry suit but not from the ocean water. It is from sweating when riding. The best part of the union suit is that it wicks the water away from your skin so you stay super warm even in very cold conditions.
A tip on the dry suit is to make sure you let the air out of the suit every time you get in the water. Go into the water up to your neck and you will feel all the air rising to your neck. Put your finger in and release the neck seal to let the air out. If you do not I fund sometimes the suit will get some water in the ankle seals when I am sowing after wipeouts.
I hope this info is helpful and I will keep adding for each article of gear.
Ok I’ll go over gloves in the next post.
kkwedell
x-h20.com
Walnut Creek
I just wear a full 4/3 kiteboarding suit. 3 mil booties, 3 mil gloves, and a 6/5 hood. As long as the wetsuit has sealed seams you will be good it waters around 50+.
Gloves - I normally wear the Jettribe RS-15 gloves - they have held up really well to use and are good for summer riding.
As it got colder I tried a bunch of gloves - first I tried 5MM surfing gloves and these 7MM claw gloves from Bilibong
The finders are only slightly precurled so you get some fatigue from wearing the gloves.
These work very well to keep your fingers warm but - and this is mission critical - the wrists are tight and thus your arms pump up - no good
I have these NSR golves in 3MM
Natural - they do not fatigue your hands but are too cold
These NSR gloves give great feel on the grips b/c they are think but are too cold - NSR Maverick
The best / warmest gloves I have used are the Stohlquist Maw - no arm pump - very warm - but still a bit too cold for winter riding.
I have these Hyperflex Claw gloves and I think they are going to work as they do not have a tight wrist so I hope they do not cause arm pump.
the kokatat is gore terx and lets the sweat out,with a good polar tec 200 liner its about as good as gets for surf riding
Master is that what you run? I'm liking the neoprene extra warmth vs the bag suit. Plus I'm just not sure it would breath out all the moisture from inside. What is your experience with them?
I'm wearing a 4/3 quiksilver wet suit with 5 mm booties, 3mm gloves, and 2 mm hoodie and the water is high 30's to low 40's. The air temp was 32 last time out and I got a little cold near the end of riding. I'm thinking about getting a thicker wet suit for winter riding or maybe investing in a decent dry suit. Still trying to decide
Lostcreek - good stuff - are you fresh water or surf? What hood are you running? How are you hands - cold or ok? What gloves?
Just freshwater so far but we've been riding the wind swells in the columbia river gorge and I'm in the water quite a bit. My hands are ok for 20 to 30 minutes and then I gotta take a break and warm them up but I'm going to drill and tap my bars and run hot water to them so that should take care of that. All my gear is quiksilver. I was really impressed with how stretchy and how warm the wetsuit is. It's the ignite 4/3mm and it feels like I'm wearing a normal 2/3mm suit. I think I'm gonna order up either the 6/5/4 or 5/4/3 cypher wetsuit with the full hood.
Sanoman
AbouttoKrash
NE Tenn
Sounds like the set up l have jet pilot 4/3,same booties,shoes are 3 mil,but no hoodie.Our water is around 45-47 degrees.You guys are running in some cool water.brrrrr
Good stuff - lots of reports of the pissers on the bars working well or with a quick release tube so it goes in your suit. I'll get a report up on our first super cold ride next week I think.
Have tried a lot of different options and the best i've found is a float coat, 1mm rash guard, john style wetsuit (I use a 2/3 slippery john), 1mm neo socks, seadoo riding shoes with 3mm inner sock. I also use hand warmers and standard summer gloves. For hand warmers, i run a line to my bars and have a barbed fitting ithe bars where it attaches. This pressurizes the bars with hot water, then i have small holes drilled in the grips so that the hot water seeps out through your gloves....works great!
The downside of relying on handwarmers is that if you break down, you have little time before your hands turn to stone.
I've ridden in water 34 degress and colder with this setup and I'm usually more than warm enough when riding. The real shivers come in when you stop riding and are putting your stuff away and getting changed!
Good thread!
The coldest I ride is 40F water temp and 40F air temp, but I feel I could stretch a little colder with my gear. I use a 5/4 xcel infiniti drylok suit with 7mm xcel infiniti drylok booties. I still havent figured out my hands, last time I used regular summer gloves and it got a bit brutal, but it was doable. This year im going to use probably 1.5mm xcel infiniti gloves.
I cannot emphasize enough on quality gear. My suit was close to $500 I think and booties $80. Both I got from a local surf shop which was really helpful in sizing. With this gear, I only twice got water seep in by the hood after hitting the water hard. The real concern is a big hit of cold water to the face could potentially knock you out. I felt like that once. Never ride alone in cold temps.
