- Missouri
Hello,
My engine lost power last night due to a rear piston / cylinder failure of some sort.
When I pull the cylinder, what should I look for to determine if the issue was due to a seizure or a ring catching?
The engine had 9.4 hours on it with no leaks and measured between 145-150 psi at 3 and 7 hours.
Here's my specs if this helps diagnose root cause:
Thanks!
- Pistons: Pro-X (718) bored within spec
- Ported cases and cylinder
- Thrust girdled head with 35cc domes
- Delta Force 2s
- Dual 38s (75 pilot, 137.5 main, 1 turn on low speed, 1.5 turns on high speed, 43 pop off)
- Gas: 40:1 - Castor 927
- Epic
- Lightened Flywheel
Thanks!
