Quinc
Buy a Superjet
- California
Bought a Waveblaster from a member here and he was kind enough to install a Coffman exhaust onto it before he sold it to me. After about 8 tanks of fuel it stopped running. Popped the hood and it was full of exhaust. Upon further inspection 4 bolts are missing! So it looks like the threads on the bottom one are jacked as the hole seems wider and ob longed shaped. Out of the two holes on the side of the manifold one has about 1/4 inch tell it hits a broken off bolt. The other one has about an inch or so before it comes to a stop, I am not sure if there is a broken bolt or not. Well out of the 4 bolt's that are missing I was only able to find 2 so I am thinking that the two had to much pressure/vibration and finally gave? Or is this something that's normal for wb1's?
So the question is how do I get them out, and how big I can re-tap the holes so I can fit larger bolts in? Also how do I keep it from happening again? The engine is a 61x.
3 bolt's that are missing:
Hole that is bit ob longed I am not sure if the bolt broke off or came loose?
Bad pic of the three holes:
The deeper manifold hole:
Broke off bolt about 1/4" in on manifold:
Exhaust side of missing bolts:
