How I assembled my solas pump without a press
High Speed Industries
Your one stop shop for quality parts @highspeedind
Ok so before I start I'm sure some people will not like my method of building my pump. If you don't like it start your own thread. I build my pump this way because the first time I built it I used a press and it damaged the bearings. I do know how to how to use a press and how to press in bearings correctly. The tolerances are pretty tight and since its stainless on stainless it takes quite a bit of force to get the bearings all the way in.
Oh and as a reference I used sealed nachi bearings so I don't have to worry about grease. The bearing number is 6205 and you can get them on eBay. For the seals I just used oem Yamaha seals.
Now I'll explain how I put my pump together BY HAND. First off I didn't use any special tools.
I used a shot light, vice, lazer temp gun, welding gloves, some sockets, my kitchen freezer, and a hammer. Ok so the first thing to explain is that metal expands when it is heated and contracts when it is cooled. This is how I overcome all of the tight tolerances. So my first step was to install pump seals, and then heat up my pump housing. For heating I simply just place the housing on the shop light. Make sure to set the housing SEAL SIDE UP so you don't end up cooking the seals! I heated the housing till the top of it was 200* the bottom was much hotter because it was resting on the light. While the housing was heating up I placed my bearing in the freezer.
Once everything was heated and cooled I installed the front bearing. To do this I just set the hot housing on my table seal side down and the I just dropped the bearing in. Right away it went all the way down to the bottom with no force. But just to make sure it was seated I used a socked with an extension and a hammer and I lightly tapped the bearing on the OUTER race to make sure it was seated all the way.
Then I let everything cool down and reach the same temp. Once everything cooled the bearing was snug inside the housing just like it would be if you pressed it in there.
The next step was to cool off my driveshaft. I just put it in the freezer. If you don't have a big freezer you can also use a bucket of ice water.
While the driveshaft was cooling I heated up my other bearing on the shop light. Be careful not to get the bearing too hot because you can melt the seals. Once everything was hot and cold i put the rear bearing on the driveshaft. It dropped all the way on with no force.
To make sure the bearing was seated all the way I used a socket and hammer so I could lightly tap the INNER race of the bearing.
After I installed the bearing it went back in the freezer.
Next step is to once again heat the housing with the seal side up and freeze the driveshaft with the rear bearing installed. I heated the housing to the same 200* as I did the first time. I measured at the snout where the seals go. This time both the housing and the front bearing were getting heated. Once everything was hot and cold I put the housing in my vice with the seal side DOWN and I just slid the cold driveshaft into place. Once it was installed I lightly tapped the driveshaft with the hammer and then I lightly tapped the outer race of the rear bearing to make sure they were both seated.
The heating and cooling worked so well for me that the rear bearing could actually spin in the housing because it was so loose. Once everything reaches the same temp it was all nice and snug like it should be. Then all you need to so is install your pump cone and you are ready to go.
I hope this helps some people out.
BruceSki
Formerly Motoman25
Long Island
That's the way we do them at work on big pumps. We have freeze spray in a can. (Which I assume is a liquid nitrogen type thing) and we have a bearing heater. It comes in a cone shape and has a special grease/wax pencil that melts at a certain temperature. I want to guess and say 250? You keep trying the pencil on the inner race of the bearing. Once you write on it and it melts its at temperature. They slip right onto a shaft like nothing after that. Then let em cool naturally and they are pressed onto the shaft.
Nice write up!
technique looks good
hope yours lasts more than 10 hours mine lasted :rant:
When I built it with the press it felt rough from the start and it lasted about 5 min. It also happened when I went out of town to ride. The rest of the day I was stuck riding a wavejammer.
Doing it by hand makes it easy on the bearings. So far so good on this pump, but I only have a few hours on it.
If needed I can also post something about removing the old bearings, all you need for that is a vice and a brass or dead blow hammer. (if you don't have either a regular block of wood and a hammer will work). I can write it up later, I just need to get some pictures first.
Iowa
I built my pump this way it was a real eye opener when the front bearing dropped all the way to the bottom good write up
Proformance1
Liquid Insanity
Vendor Account
New York Crew
Great write up. This will work and is awesome for anyone but remember that the tightness in the final C3 clearance bearing is not affected by this method. This will only save your setup if you were pressing together incorrectly. The tolerances are still the tolerances, if it was too tight or loose last time, it will be this time also.
waksk8
Jacksonville TX
So glad you posted this. Put my pump together last night fallowing your direction and worked great. When I was installing the drive shaft and rear bearing in the pump I had to tap it down about 3/16 on an inch. Think the only reason was I didnt let the shaft and rear bearing get cold enough, but still went down the 3/16 easy.
StandupEd
Eddie would Tow
Is there a DIY way to slightly increase the bore like a brake caliper hone?
CRJ
Hibernating
Toronto
im surprised this isnt the mandatory way to do this. ive used the same process for doing ring and pinion gear swaps on my prerunner.
Oregon
x2
