onesojourner
I use a thumb throttle.
- springfield, mo
this write up is for a round nose superjet with REV footholds. It will also apply for most other footholds. It is even easier on a square since you don't have to wrap the turf all the way around. (but I will laugh at your bruised elbows) I pretty much cut my turf into thirds and that was just enough to do both sides and the bottom. if you want to do the dash and the hand pole you will need more turf. I am starting after you have roughed up all the paint (make sure you do a good job on the top outside edge of the tray!) and coated the whole side of the the tray and piece of turf with contact cement and let it dry then applied a second coat and let that dry. you will have some seems in the footholds but they are not very obvious.
Supplies:
Dap Weldwood gel or reg. Available at lowes, home depot, walmart, ace ect...
dowel rods
heavy paper/wax paper
1-2 sheets of turf
3-6 cheap 99 cent paint brushes
rough sandpaper 36 grit or so
rubber mallet
razor blade
heat gun
Picture #1
I used dowel rods (about 3/8 is what I used) to keep the turf from touching any where that I do not want it stuck to. I could not get dowel rods to work at the back of the ski so I used some heavy duty paper. start on the side/front part of the tray that I have labeled with the red box and work your way towards the front. just worry about the side for now. don't stick it on the top yet. leave the dowel rods up there as long as you can. Take the rods out as you move along the side. Don't let turf get stuck on both sides of the rod or its going to be tough to get it out.
Picture #2
once you get past the peak of the hump is when things start getting tricky. This is when you are going to need to have the heat gun handy. Just warm it up. Not so hot you can't touch it just get it warm. Just move the heat gun back and forth until its all warmed up. You need to push the turf in toward the hump and then around. Once you get with in about 2 inches of the paper get rid of it. Its easy to get it stuck on there.
Picture #3
Now its time to start getting it wrapped around the corner. You kind of just do the corner (circled) and the back of the ski at the same time. Then just work your way from the corner to the front of the ski. Make sure you heat it up. If you don't use heat here its not going to work out. You might need to trim a bit as you go. The turf is going to be in some very unnatural positions and it wont want the stay there. Just make sure you are just making rough cuts. Leave about an inch hanging over everything and then you can go back and do the final cut. Heat the knife up a bunch with your heat gun. If its hot enough the heat gun will cut through the turf like butter. Don't heat the turf up to cut or you will rip it.
Supplies:
dowel rods
1-2 sheets of turf
rubber mallet
razor blade
heat gun
Picture #1
Picture #2
Picture #3
