The -2 was 10.5 lbs
new?
do we have pictures of the new? what was changed?
:smile: Only the wall thickness of the Tube.
I believe eventually we'll be able to make them less than stock weight...
but 1 step at a time
Not only is it at least 4.5LB heavier, almost all that weight it at the head so as far as CoG goes, this +4.5LB figure is compounded.For reference I think the RRP is 15lbs
I don't think people will be selling their old XM pole to buy a new XM pole just because they want to shave 1LB. If the new XM pole was 1LB lighter at the head area, then I could see this happening but the 1LB savings is spread across the whole pole. I'm thinking in terms of CoG.hopefully some old XMW poles will go f/s...... dibs
