Y
yamaslut
Guest
OK...... been wanting tubbies for a while now, but was afraid they would not stay on...
I'M NOT AFRAID ANYMORE!!!!
I think between talking to "the master" (Doc Wok) and some others (Neil, Robert) who have installed them I feel a lot better about the whole process... I got some great tips too...
Here goes:
Here goes:
- grind about 1-2mm of the foam on the inside of the Tubbie and on the edges of the tubbie, grind off about 4-5mm.
- rough up the inner lip of the Tubbie w/ 36 grit sandpaper or a grinder (if you feel confident using one)
- lay Tubbie flat on sheet of fiberglass matte, trace w/ sharpie and cut offset to the center 3-4mm (2 per side)
- repeat steps 1-3 w/ other Tubbie
- make mark to position rear of Tubbie 36.5" up to 38" from rear and 3.5" up from bottom on the side of hull
- make mark to position front of Tubbie .5" from bottom of hull
- trace out Tubbie on side of ski w/ sharpie
- grind w/ high speed angle grinder using 36 grit paper everything inside the Tubbie outline traced on the hull. I usually go about 20mm over for flairing in the Tubbie later
- re-trace Tubbie back onto side of hull as said in 5, 6
- predrill holes w/ 9/64" drill bit and screw Tubbie to hull and ensure it is where you want it / remove Tubbie
- mix up approx. 2 pints of you favorite two part epoxy and add cab-o-sil to thicken it up good... don't use too much or the matte wont soak up good
- pour epoxy into tubbie spread w/ paintbrush, lay 1 layer of matte, pour more epoxy, lay 2nd layer of matte... make sure it's all nice and wet
- make sure hull is layed on it's side so epoxy doesn't all drain out of sides when you screw it in
- screw Tubbie to side of hull and flair in the edges of the Tubbie w/ the epoxy/cab-o-sil mix.
- let dry and repeat steps 5-14 for other side
