Unmolested 02 SJ.....For now.....
Endo
Non-tree hugger
Hi guys! Just recently joined your forums for some information sharing. I have been on a few ski forums in the past and must say you guys rock:headbang: The only problem now is I'm facing a complete info overload!!!! What to do!!! what to do!!!Where do I start!!!:hail:
I have a completely stock 02 SJ (other than a 500 gph bilge) that is just waiting for a little TLC.....and stock machines just aren't in my nature. I've owned it since new and have around 50 gallons thru it.
I ride on flat water (lakes in Northern Indiana) mostly and have some of the basics down. Such as tailstands, nose stabs, and the occasional sub. And of course running buoys. Most of these I learned on a highly modified 440 before the SJ but quit riding allot for various reasons. Got down to the point where I only had time for the occasional blast around the lake. But now it is time to play again!!!
I'd really like to further the ski's ability and my own....more towards freestyle that is. So I'm asking for peoples help on which direction to take. I have my ideas but it has been a long time since the days of the 440/550's so my knowledge of ski's may be a little behind:rolleyes:
Thanks ahead of time and am attaching a pic of the motor since I am guessing it has been a while since you guys have seen stock.:bigeyes:
Danny Kay
SJ + M3 = awesomeness :)
Atlanta
Welcome back. Im fairly new too, i bought a fairly stock 01SJ a little while back. It came with footholds, and honestly I cant imagine what it would be with out them. That with a few pump mods and its a darn decent ski IMO. Personally, i would look into footholds as one of your first mods, but thats just me. Is there anything that feels wrong about your ski, beside too little power (always a problem)?
michael950
for me to POOP on!
Houston, TX
I have a completely stock 02 SJ (other than a 500 gph bilge) that is just waiting for a little TLC.....and stock machines just aren't in my nature. I've owned it since new and have around 50 gallons thru it....
I'll buy it from you for $1000. :biggrin:
Y
yamaslut
Guest
in order of modification:
  1. reinforce skis engine compartment and tray
  2. worx 201 intake grate
  3. skat trak 12/15 freeride swirl prop
  4. cut your pole down to -4"
  5. 0 degree straight bars/X-metal steering
  6. footholds
  7. turf
  8. Blowsion Tubby 2's (sponsons)
  9. one way valve/scupper
  10. dual cooling
  11. Factory B Pipe
  12. milled stock head
  13. MSD ignition
  14. porting (LPW)
  15. lowered hood kit (tons of options) I am using the waterdawg hood, very well priced
  16. more motor and hull upgrades
It's my belief that handling mods should always be done first before engine mods
yamanube
This Is The Way
Staff member
Mandalor
Personally (especially for flatwater) I would say
-Impeller (absolute necessity!!)
-Intake grate
-Bilge pump(s)
-Footholds/turf
-Cut pole 2-3"
-0*bars and ODI grips
-Bpipe (or freeride dry)
-Aftermarket head/dual cooling
-MSD enhancer
That would be a great start and make you really like your boat!
Endo
Non-tree hugger
Danny Kay...The machine feels big to me and difficult to flip around...but then again compared to the 440/550's....what can you say. And as far as power I like the bottom end but would like more around the 1/4 to 1/2 mark. And don't even get me started on the stock pads!!! I am planning on turfing the tray but need to figure out footholds first.
And michael950....WOW that is tempting!!!...Let me think about it....:nono: Gonna have to say no to that one.:moon:
yamanube
This Is The Way
Staff member
Mandalor
If you want some killer pow from 1/4-1/2 throttle get your self a dry pipe (factory type4 or riva freeride) they make killer mid range!
I have posted this before, but I figured I would copy and paste it into your thread so you can see a good step by step break down for modding an SJ.:biggthumpup:
Honestly I think it's best to take it in stages kind of like Wamiltons steps he has on his website. I know they're kinda cheesy and his packages definitely are not the cheapest route, but I agree with his logic.
This is how I would do it.
Stage 1
-Worx 201 Intake Grate/JD Intake Grate
-Skat Swirl
-Stick with stock rideplate for now(D-cut later)
-0 Deg Bars
Stage 2
-Footholds/Turf
-Shorten Stock Handlepole
-Shortened Turn Plate and UMI Steering if you dont mind spending a little more
-Seal Stock Hood!!!
-Reinforce
-Hood Straps/Handlepole Limiting Strap
Stage 3
-Bpipe
-Girdled Head
-Carbon Tech Low Tension Reeds (Until you're ready to spend the big bucks on some really good reeds)
Stage 4
-Enhancer/Modified Stock CDI
-Lightened Flywheel
Stage 5
-Porting
-Bigger Carbs
-Better Reeds
Stage 6
-Aftermarket Hood
-Aftermarket Handlepole
-Scupper
-Tubbies
Right now I've completed stages 1-3, enhancer, and a few other things I have added along the way. So far I am very very happy with my setup. :Banane01: Now if you preferred more power before footholds/shortened handlepole then you can go for Stage 3 or at least a bpipe before you start on Stage 2. Personally I think Stage 2 should come first though because they are relatively cheap/free mods that require more time/labor on your part than anything else.
Now if you had unlimited amounts of money then go for it all. This plan is more for a person on a budget like I was when I was building up my sj.
Whats really cool about doing it that way is if you're someone like me who is relatively new to the sport and wrenching then you can do pretty much everything yourself up until Stage 5. When it comes to tuning the ski the package you have put together is such a common package that you can get a ton of help and guidance. I've learned so much in the past couple of months setting up my ski and definitely wouldn't have been able to do it without the X and some really helpful friends.
:hail: :hail: :hail: X-H20
By the time you are ready to get into Porting and bigger carbs you have a good understanding of the 701 and you'll be able to get the most out of and properly tune that new ported motor.
Good Luck:biggthumpup:
Y
yamaslut
Guest
Stage 1
-Skat Swirl
-0 Deg Bars
Stage 2
-Footholds/Turf
-Seal Stock Hood!!!
Stage 3
-Bpipe
-Girdled Head
Stage 4
-Lightened Flywheel
Stage 5
-Porting
-Bigger Carbs
-Better Reeds
Stage 6
-Aftermarket Hood
-Scupper
-Tubbies
I like your list, very well put together....
Indiana
Whoa! Somebody in Northern Indiana! Very RARE on this forum. I'm in Elkhart, used to have a cottage an Wawasee growing up. I'm trying to get ahold of a freestyle modded roundnose if you know anybody that is selling.
I'll be out in your area some this season. I have five skis (three running) and a triple trailer and looking for any opportunity to learn more about freestyle!
There is tons of info on here that has helped me avoid many pitfalls!
michael950
for me to POOP on!
Houston, TX
Stage 1
-Skat Swirl
-0 Deg Bars
Stage 2
-Footholds/Turf
-Seal Stock Hood!!!
Stage 3
-Bpipe
-Girdled Head
Stage 4
-Lightened Flywheel
Stage 5
-Porting
-Bigger Carbs
-Better Reeds
Stage 6
-Aftermarket Hood
-Scupper
-Tubbies
May I suggest adding reinforcements at stage 2, since you are working with glass anyway (footholds).
michael950
for me to POOP on!
Houston, TX
.....tubbies should be the first thing on the list not last
When you compare the number of riders that have tubbies or reinforce, reinforcement is more common. Thus I felt it was more important to emphasize reinforcemnt....
Besides, tubbies are one of those things that are rider preference. Kind of like a wet wolf cone, or blueprinted pump. Not as essential.
I would have put them higher on the list, but in my opinion I would much rather have a bpipe, etc before Tubbies.
In my opinion parts like Tubbies, hoods, and aftermarket handlepoles aren't that necessary to be able to have fun on a superjet while a pipe, prop, etc are a MUST.
Now if you have the $$$$ and you've ridden a ski with Tubbies and like them then I would put them up there with the footholds stage.:biggthumpup:
Endo
Non-tree hugger
Very Good suggestions!! My thoughts were leaning the same way with the handling. Fly...why do you like those intake grates? Pro's/Con's? And I may move the B pipe up a little on the list. Question there too. The b pipe seems to be the one everyone runs? But Factory's site doesn't call them b pipes? Are they still the same? Good place to get them? And the Glassing:bigeyes:
I don't mind turning a wrench but that makes me nervous but allot of people on here seem to be comfortable with it. Is it that easy???
Keep the ideas rolling!!!
and drodabaugh...occasionally ride Tippy/little Tippy. Beers cold and the wakeboarders leave a great wake. And the view at times:woot:
michael950
for me to POOP on!
Houston, TX
Endo, your going to need to search for the answers to your querstions.
Many answers can be found in the Tech FAQ.
There is info about different exhaust systems, glassing, reinforcements, etc.
Great info!
Y
yamaslut
Guest
if you move the "B-Pipe" up on the list, definately get the prop and intake before or at the same time.
Yep just like Yamaslut said, prop and intake grate FIRST. Oh and 0Deg bars also cuz the stock ones absolutely suck.
Then I would start working on the Stage 2 items cuz they are mostly free aside from the Footholds and while you're working on Stage 2 keep an eye out for a used Bpipe and girdled head so you can save some money buying used. If you get to the point where you have to have a bpipe you can always buy one new.:biggthumpup:
