First Mods for your New Superjet
Y
yamaslut
Guest
option 1
in order of modification:
  1. reinforce skis engine compartment and tray
  2. worx 201 intake grate
  3. skat trak 12/15 freeride swirl prop
  4. cut your pole down to -4"
  5. 0 degree straight bars/X-metal steering
  6. footholds
  7. Hydro Turf
  8. Blowsion Tubby 2's (sponsons)
  9. one way valve/scupper
  10. dual cooling
  11. Factory B Pipe
  12. milled stock head
  13. MSD ignition
  14. porting (LPW)
  15. lowered hood kit (tons of options) I am using the waterdawg hood, very well priced
  16. more motor and hull upgrades
It's my belief that handling mods should always be done first before engine mods
option 2
Stage 1
-Worx 201 Intake Grate/JD Intake Grate
-Skat Swirl
-Stick with stock rideplate for now(D-cut later)
-0 Deg Bars
-Bilge Pump
Stage 2
-Footholds/Turf
-Shorten Stock Handlepole
-Shortened Turn Plate and UMI Steering if you dont mind spending a little more
-Seal Stock Hood!!!
-Reinforce
-Hood Straps/Handlepole Limiting Strap
Stage 3
-Bpipe
-Girdled Head
-Carbon Tech Low Tension Reeds (Until you're ready to spend the big bucks on some really good reeds)
Stage 4
-Enhancer/Modified Stock CDI
-Lightened Flywheel
Stage 5
-Porting
-Bigger Carbs
-Better Reeds
Stage 6
-Aftermarket Hood
-Aftermarket Handlepole
-Scupper
-Tubbies
RECENT THREAD LINKS:
Unmolested 02 SJ.....For now.....
advice on mods for stock superjet
Help and advice needed for my 701 freeride/freestyle build
http://www.jetskier79.com/gallery/v/yamaslut/album40/
help what mods to do to this superjet.
Superjet build up, some advice needed.
TECH SECTION LINKS:
browse through this section for tutorials on listed mods
http://www.x-h2o.com/forumdisplay.php?f=26
feel free to add your ideas and mods you would do in order of mod... we can make it the end all for people wanting info on first mods for a SJ...
make a list like FLy and I did...
