Y
yamaslut
Guest
Ski Parts
Slippery Switch vest (Red) 07
Slippery Matrix Gloves 07
Slippery long sleeved Rash Guard (Red) 07
Fox (heavy duty) Riding Shorts
Cascade Helmet w/ cage
Nike Maxsight contact/sunglasses (thanks Idok, Shonuff)
Sponsors
LPW (Lehr Performance Watercraft)
Hydro Turf
Slippery
Fuel Clothing
AZHIAZIAM
Skat Trak
Leg Drag
Nascency Project
X-Slide Shop
more:
http://www.jetskier79.com/gallery/v/yamaslut/album40/
- 61-x cyl
- LPW porting
- Big Bore (LA Sleeve)
- Bored cases
- PortedEpoxied cases by LPW
- 85mm Pro-X piston
- ADA girdle head
- 35cc domes @ 185psi.
- Hot Rod Crank
- Dual 44mm mikuni carbs w/ dual pickups
- Tau Cetti F/A's
- Outerwear pre-filters
- Carbon Tech reeds
- Riva reed stuffers
- Riva space plate
- ported and matched Factory B Pipe w/ mod chamber
- stock waterbox
- flow control valve
- 2.5" single front ehaust
- stock 62t electronics
- MSD enhancer,
- 2* static advance
- stock pump w/ bored exit nozzle
- quick turn steering nozzle
- stock ride plate w/ modified "d' cut
- worx 201 intake grate
- modified Solas 12/15 w/ 3mm cutback swirl freeride prop (modified by IMPROS)
- Wamilton motor mounts
- Blowsion "Kenney Keepers"
- XMW -4" X- pole custom painted "one off" pole by Daylite Ramsey
- XMW -2.5" turnplate
- XMW straight bars
- XMW throttle pull
- ODI grips
- WF pole pad
- Blowsion Tubbie 2's side sponsons
- WD Hood kit (Diablo)
- WD Nosepiece (Diablo)
- WD REV footholds (rear)
- Widened tray mod 16" rear, 21" foothold, 13" front
- Highroller foothold (front)
- single 2.5" one way valve (Lowes)
- single 500gpm Mayfair bilge pump w/ lanyard
- Dangerboy bar ends (skull heads)
- Hydro Turf under-padding 25mm
- Hydro Turf Diamond moulded (black) turf
- yellow faux hair on pole pad
- Carbon Fiber Re-inforcement on sides
- fiberglass reinforcement on bottom and tray
- Custom Yellow, Black paint w/ sponsor logos
Sponsors
Hydro Turf
Slippery
Fuel Clothing
AZHIAZIAM
Skat Trak
Leg Drag
Nascency Project
X-Slide Shop
more:
