nikad58
1974 YZ 701
- 200 miles west of Havasu !
This trick can get you into trouble and piss off anyone close by..
Spray/Squirt in the tray..
To do this with great effectiveness its good to just look at the pump on the trailer to see what the nozzle is doing when turning and understand whats going on.. Now that you see that to turn either way the nozzle turns the other.. It pushes the back around rather than turning the front (like a bike).. ok.. If the ski is leaning and the nozzle is turned the other way, It will be pointing out of the water..
Now if you turn left and lean the ski left (until the pump is just about to let loose) then unwieght your ski, throttle down (to pop the pump out of the water for just a flash) then you turn the bars the other way and gas it just as your pump hooks back up. Wooosh you can shoot water for 50' no problem and ride away without even slowing down much.
Remember water cops hate to see that and will bust you in a flash ! BIG ticket
Racers will punch you in the face if you do it to knock them off as they are passing you !
Boaters will throw beer bottles at you and try to run you over..
People on the beach will throw rocks (when water hits the beach it will throw up rocks/sand and hurt people)
Its a show move only ! Looks really cool !
Please only practice away from anything/body
Once you get it down you can pretty much hit a bullseye 20' away with a spray hard enough to knock someone right out of thier tray from 10'
