sxr with .w f footholds ,jettrim rail caps
Bigfish
Bigfish
North Carolina
Well there in, caps are on! Jettrim caps are AWESOME!!! They fit w/ almost no trimming. Use 1/8" aluminum spacers, under front mounting holes & rear hole, and you will have no problem w/ the fit. Water Craft Factory footholds worked great in SXR, no problem w/ exhaust tube if you mount all the way at the back. Sorry for lack of preinstall pics of footholds, battery dead on camera.
Bigfish
Bigfish
North Carolina
turf job
This was my first turf job with out a kit. Thanks to the "how to" threads it turned out great All the tricks worked, using the heat gun and wax paper did the job. I used 2mm foam sheet from hobby shop to make patterns, it's alot like super thin turf. .
Subtacular
All or nothing
Bullhead city Az
It looks really good. So how hard was it to remat it?
