FX-1 FX Kawasaki pump conversion stuff
curt248
01 superjet 94 fx1 97 xp
Chicago IL
Does anyone know where to get the bearings (bulk head around the 900zxi driveshaft) for the fx-1 kawi 650 pump conversion? Special said that some have found them.
curt248
Chicago IL
I wonder if those bearings worked well? Anyone know the inside and outside diameter of the bearings so I could try a local bearing supplier.
I tried to call the canadian bearing place in the post today at 1pm central time and they said they are open between 8am and 5pm but are closed now.
Hi,
I'm collecting all parts for my 650 conversion (just miss the time to begin :D)
but i've not succes to remove the coupler from the zxi shaft ... anybody have some advise ?
thanks
seatsR4toilets
Just spell my name right
In Your Head
Ok, I got this Kawasaki bearing carrier.
Is this the correct one for the conversion, and, the rubber in pretty cracked up. Is that ok, do I need to find another one?
The pic is in the next post.
seatsR4toilets
In Your Head
Pictures:
