I should've started this a while back but didn't so some details will be left out for sure. Here is what I've got so far...
Hull
Custom rattle can paint job
Custom footholds but seriously considering the flat deck w/footstrap conversion
Aluminum handlepole
Quick turn steering
Jet Dynamics intake grate
Modified hood for better air flow and less water intake
Engine
Cylinder bored over 1mm so the displacement is 762cc
Factory Pipe
Timing advance plate
Milled stock head
Drivetrain
12/17 Skat Trak Swirl prop (just sent to Impros for a clean up)
WW freestyle cone
X2 trim currently at 30° up but non functional
Currently this setup is tipping the scales at 300 lbs. with more to lose!
Hull
Aluminum handlepole
Quick turn steering
Engine
Factory Pipe
Milled stock head
Drivetrain
WW freestyle cone
