re sleeving
wetjet701
Always On
Who do I need to talk to about putting a resleeving thread in the tech forum? Or should I do a step by step write up on this and it will just be moved there?
wetjet701
Always On
Ok The first things you want to do is set your oven to 450 deg, put your new sleeves in the freezer and gather your tools.
Tools Hot mit, 5x5 piece of wood and a rubber mallet
wetjet701
Always On
Once the oven hits 450 put the cylinder in the oven for 20min. After 20min remove set on a flat surface and smack the bottom of the sleeve with the mallet they should slide right out. If they don't, don't worry just put it back in the oven remember with this project heat is your friend.
wetjet701
Always On
Once the sleeves are out put the cylinder back in the oven for 20min again. Remove put it in a vise get the sleeve from the freezer. Align the ports the sleeve will either drop in or just put the piece of woog on top of the sleeve and tap it a couple of times it should dop in smoothly. Remember do 1 sleeve at a time and bake cylinder 20min for each sleeve replacement. I only did one sleeve in this rightup.
Waternut
Customizing addict
Macon, GA
Good write up... Wish the kawi cylinders were so easy.
You will most likely have a few seconds to move the sleeve around and line up the ports. You don't have a real long time so that's why you'd want to line them up fairly well before dropping it down.
wetjet701
Always On
If you don't get it aligned the first try just reheat and keep trying. As I said before with this project heat is your friend.
wsuwrhr
Purveyor of the Biggest Brapp
...a few things to add.
First,
Heat CAN BE your friend, but just don't get the cylinder too hot. 450 is pretty warm. You can easily anneal the cylinder by getting it too hot and letting it cool too slow.
Second,
The sleeve will need to be "seated" after it cools. It is no secret that when the cylinder is hot, it slightly expands or "grows" in size. The sleeve is cold, or better yet at room temperature. Well when the sleeve is dropped in, it rapidly heats up to the cylinder temperature, hense it grows as well. Well now as the parts cool, they shrink. The sleeve will not be sitting exactly on the counterbore step anymore.
Well this is all well and good until the cylinder head gets bolted down adding tons of pressure to the sleeves, or the motor detonates a few times, or the jetting gets a little lean and the motor gets nice and toasty.
Then the sleeves drop just slightly to sit on the c-bore step. Blown head gasket or o-ring.
Third,
I can't imagine the sleeve sitting exactly at the level of the cylinder deck, so it will be slightly sticking up or down in the hole, so it will need to be decked and bored anyway.
Brian
Kennay
Squarenose for the _____
Myrtle Beach, SC
First,
Second,
Third,
Brian
So after you get the sleeves in, bolt it to a stock head and stick em in the oven, remove and retighten. Complicated, eh.
wetjet701
Always On
Mine always drop directly in the counter bore that is why I use the wood block and mallet. Can't you tell in the last picture how well it is seated?
wsuwrhr
I am talking .005-.01 thousands, .1-.2 MM, not much gap, but IMHO, the sleeves need to be seated in a press.
Not veiwable in a picture, at least not by me.
Otherwise, good thread.
Brian
Kennay
Myrtle Beach, SC
Who is humiliated? Nobody corrected me, and you didn't even catch the mistake. I did once I read it again.
