Powerplant: Tuning Carburetor, Exhaust, compression, engine setups, etc.
michael950
for me to POOP on!
Houston, TX
Engine Information- Configuration Setups incl. pistons 62t vs 61x lamey big bore
Engine Types:
The Great 61X/62T Debate, Philosiphized....
The usual suspects beating the dead horse. :pokey: I know this will be a good read, and probably confuse you to the point you don't know what to do.
PWCT: 62t to 61x whats the difference
lamey vs. 701 super-bore
Good advice on spending the cash before you have the skill. Consensus is, start with what you have, build as you go. As your skill gets better and you need the power to move on, then spend the big bucks (unless you get a sponsor).
Pistons:
ceramic coating pistons
Pro X / Wiseco Pistons
Buy Wiseco pistons individually or as "matched" pairs?
Misc
best motor mount for sj?
Member preferences for motor mounts
Using Devcon putty to fill 62t cases
michael950
for me to POOP on!
Houston, TX
Carburetion - Single dual carbs AND Intake - reeds reed spacers Popoff Pop Off Chart
Single Or Dual Carbs
Single 44mm into Duals?
Surf use - OEM38s Vs. OEM 44s
What kind of paint to paint carbs?
? on adjusting my carbs - One of the many posts on B-pipe jetting
reed spacer or stuffer? - Comparisons and functions of each.
Mikuni Spring Color & Popoff Pop Off Chart - PHOTO Included!!
My notes from a Mikuni seminar by Herb Kane - Includes stock flow rates
MANDATORY READING: Mikuni Watercraft Carburetor Owner's Manual
Despite the page count, it is an easy and somewhat quick read.
FYI: I scanned a pamphlet about tuning your ski I received with a manifold I bought. Hope it helps.
michael950
for me to POOP on!
Houston, TX
