760 build for the Blaster
Q
QuickMick
Guest
Few pics of my build, I just set the crank in tonight. I hope to have it done by Sat. If anyone sees anything wrong let me know.
Oh yea I sandblasted the cylinder and cases for new paint. Went over them with a dremmel to remove cast lines and sharp edges. Then I blasted them again to roughen it up for paint. Has anyone ever done this??
yamahammer
are you men the police?
San Angelo, TX
looks bueno-- dont know what your doing with the paint, but i did have my first b1 engine rattle apart due to paint under bolts rubbing off causing bolts to loosen-- i did try to get toooo blingy with a lot of metal flake-- probably never happen to anyone else, but doesnt hurt to try and prevent someone elses possible future pain
Q
QuickMick
Guest
Im going to build it, tape off all gasket surfaces and take it to be painted by someone that knows how to paint. NO rattle can for this motor.
THen im sure Ill phuck the motor up and it will be money down the drain.
Who knows
shepster
Living the dream!
Thats what happened to me, can you say AIR LEAK. cost me a fortune but lookek sweet while it lasted.
Paint after you build from now on
Q
QuickMick
Guest
You two are saying you painted the parts before assembly and the bolts loosened up because of the paint under the bolt heads??
Prem1x
Tinkering obsessed
Austin, TX
Well I just sand-blasted then rattle-canned my B1 cases this winter, so I guess I should be looking for them to come apart soon... great
but, really, wouldn't the painted alum have to oxidize a good bit under the paint for that to happen?
yamahammer
San Angelo, TX
i taped off all the sealing surfaces, but the paint i used was so thick that it crumbled under the bolt heads and caused the bolts to loosen-- boat started running like ass, i grabbed the cylinder and you could pick it up off the engine and the cases came apart-- didnt hurt anything-- just had to teardown, clean, and reassemble-- in my case i think it was the very heavy metal flake--- thats what i get for trying to be all fancy
Q
QuickMick
Guest
You got it, think i got carried away with the gun. You should be ok with a thin coat as it hasn't happened again since.
Thanks for the info. Ill prime under the bolt heads, put em all in then paint over them.
Q
QuickMick
Guest
More pictures. I had to CUT the cylinder some so the girdle bolts would clear. I guess because this motor came out of a couch the 62T had a different casting for exhaust mounts.
Im glad I checked this before I painted it and not after!!
Before cutting slots for girdle bolt.
This is the area I had to cut to clear the bolt
This is what it looks like now.
Some pics of motor going together.
Q
QuickMick
Guest
Engine stand
Today I got to thinking and wondering how my painter was going to be able to paint my motor other than the two position way I had to to prime it.
I came up with a solution. I made a motor painting stand.
its held by the crank ends by aluminum tubing. I wrapped the crank ends up with thap and beveled the ID corners of the tubing.
I had to make a lock to keep the engine up right (heavy side up).
I know its not fancy but I made it out of scrap I had in my shop.
It does work good though.
Q
QuickMick
Guest
Looks good so far!!! You should have called, I didn't do jack this weekend. You figured out if you're racing or not? I'm sure Moonie told ya but I'll help out if you need it it!
Joel I dont even have your phone # bro. I should of called you.
Races are Sept 20th and 21st in Baytown.
Q
QuickMick
Guest
Motor is painted
Brought it home from the paint shop today. I think from now on I will rattle can my own motors, unless I can find someone to paint for me on a barter basis or something of that nature. None the less its painted and its going to cure for a good week untill Im ready to install it.
Q
QuickMick
Guest
Now all I have to do is send strip the pipe and send it out to be aluminized powder coated. I checked the head pipe on my b-pipe, all the set screws turn free. :Banane09:
Q
QuickMick
Guest
Few more pics. I had to make my own Primer fittings for one carb. I thought I had a dual carb primer kit but it was only for one, so I made the other.
Carbs are a lil rough on the outside but clean on the inside. I plan on blasting them and powdercoating them in the future.
Q
QuickMick
Guest
Just a few more pics from work done over the weekend.
My anode broke so I had to make another one out of some material I have at the shop.
Motor ready for the exhaust manifold.
Manifold in place.
45 Degree barb fittings I used for the dual cooling.
Drilling hull for the new bulkhead fitting for dual cooling. I wanted to keep the stock bilge setup.
View from inside after bulkhead fitting is in place.
Motor is now in the hull.
Video to proove it runs!!
Moondance
Just plain me....
You need to change your signature.
Hurry & be "sick from work" so you can get it in the water. I'm anxious to find out how it runs.
