Freakrider
X247
- Tampa Bay area
super-ski and myself are using some of Matt_E's rebuild thread ideas plus we have the motor compartment draining out only to the very back of the ski. This drain on the bulkhead goes through a flex hose under the tray and is hooked up to a drain plug. The foam will therefore not come in contact with any potential gas or oil residue from the motor area.The idea is if your bilge pumps goes out or quit working it would not totally end your day rather you can pull the drain plug and at least have a mini drain system. The other side has a drain plug for any water leaks under the tray. I will add more pics later...we are also adding Pancake Pete's front foothold, padded gunwale tops and 25mm pad and new turf...reinforcement of hull and tray is with carbon fiber with decent prices from U.S Composites..... we both had some wet foam from leaks and super-ski discovered his tray was cracked. He gets credit for most of the labor on this buildup....again more pics later...
