- Lake Havasu City, AZ USA
We make top quality WORLD CHAMPION gasket that are PROVEN YEAR AFTER YEAR on the buoy course and in freestyle/freeride!!!
We are suppliers to many of the largest PWC shops and top engine builders in the world. If you would like to know who, just ask!
CURRENTLY, we make gaskets for every 2 stroke Yamaha, Kawasaki, and Seadoo watercraft. We have all the O-rings that these models may need also. The only model we dont make gaskets for are the Kawasaki 300! lol We make most all aftermarket gaskets for intake, exhaust pipe, and carbs.
We can cut you a custom thickness gasket that you may need from .016, .020, .030, .040, .050, .060" top quality material. With or without aluminum mesh on the thicker materials.
All gaskets made fresh daily! Ah! that new gasket smell and feel! New gaskets do dry out over time and will not crush and seal as well the first time! We dont stock bins full of gaskets and forget about it. We keep all our gasket materials bagged to keep in the freshness. There is a difference!
Ask if you need something, my list needs to be updated and there are a lot of other gaskets/seals/orings that i have.
Compare, shop, and save some money! This is for Yamaha, Sea-doo, Kawasaki Personal Watercraft.
WE MAKE TOP END KITS, COMPLETE KITS, AND COMPLETE KITS W/SEALS FOR ALL MAKES AND MODELS OF 2 AND 3 CYLINDER TWO STROKE ENGINES! ALSO CUSTOM KITS TO YOUR EXACT SPECS ARE AVAILABLE TOO. JUST MESSAGE FOR WHAT YOU NEED AND YOULL GET A QUOTE RIGHT BACK! This list is not even close to being complete, its just some of the more popular gaskets used on X-h2o. Please message, TY!
As of now, we make the most popular YAM/KAW/SEADOO gaskets of the highest quality cut using top brand KLINGERSIL® or Intermec Corp. gasket material.
All these gaskets are made in the USA and meet or exceed OEM specifications. No cheese gaskets allowed!
I also make most of the aftermarket exhaust and intake system gaskets. We also can make the gakset in whatever thickness you like.
Shipping will always be combined on multiple orders.
I take Paypal as payment.
This list is not even close to being complete. These are just some of the more popular gaskets. Message me with what you need and
Here is the current 2011 gasket/seals/carb kits list with prices:
YAMAHA
650/701/760 gaskets seals:
2205 Yam 650 6M6 Ultimate synthetic fiber head gasket $23.00
2215 Yam 61X Ult. synthetic head gasket - $23
2810 Yam 701 62T Ultimate synthetic fiber head gasket $23.00
2220 Yam 650/701/760 Base gasket $7
2250 Yam 701 61X top intake manifold $3.50
2270 Yam 701 61X bottom intake manifold $3.50
2280 Yam 650 reed block(rectangular, 2 req'd) - $2
2290 Yam 701 61X reed cage gasket(small rectangular, 2 req'd)) - $2
2310 Yam 650 6M6 Exhaust manifold $8.50
2330 Yam 701 61X Exhaust manifold $8.50
2340 Yam twin oil pump gasket - $2
2350 Yam 650/701 OEM 44 Flame arrestor(2 req'd w/brace) - $2
2360 Yam 650/701/760 Flywheel Cover $8.50
2370 Yam 650/701 OEM exhaust head pipe, SJ, WB1, etc. - $5
2820 Yam 701 (62T) dual 38 Carb base(dual hole) $4
2825 Yam 701 (62T) OEM dual 38mm Flame arrestor(dual hole) - $3.50
2830 Yam 701 (62T)701/760 intake to cases $4
2850 Yam 701/760 (62T) Exhaust manifold $8.50
3200 Yam 760 Stainless Steel head gasket .025" $30.00
3220 Yam 62T/64X 760 dual 44mm carb base gasket - $3.50
5900 Yam Factory "B" head pipe gasket(47.00mm) $7
5900BB B pipe head pipe big bore gasket(51.50mm) - $9.50
2525 Yam 650/701/760 crank shaft seal kit(all 3 seals) $25.00
5460 Yam 650/701 44mm Mikuni carb base $1.50 or 10 for $11
8024 Yam 62T/64X reed spacer, also R&D/Boyesen/Dasa A/M intake to cases - $6
12-0010 R&D Dominator YAM 62T/64X mounting speed plate - $6
9060 RIVA red pipe head pipe - All models except WaveRaider - $7.50
9070 RIVA red pipe head pipe - WaveRaider only - $7.50
9080 R&D Racing exhaust head pipe(3 bolt) - $7.50
9090 R&D Racing exhaust head pipe(4 bolt) - $7.50
2116A YAM "PREMIPRENE" Electrical box gasket for twin 650 701 760 - $20
YAMAHA 800/1100/1200/1300:
3400 Yam 800 Stainless steel head .025" $30
3420 Yam 800 cylinder base - $7
3425 Yam 800 carb base(2 req'd) - $2.00
3430 Yam 800 carb manifold - $6
3435 Yam 800 reed spacer, not a OEM gasket- $4
3450 Yam 800 exhaust manifold - $10
3460 Yam 800 exhaust head pipe - $7
3470 Yam 800 power valve(2 req'd) - $4
2340 Yam oil pump - $1.50
3515 Yam 800 Crank Seal kit(3 seals) $26
3600 Yam 1200/1300 PV Stainless steel head .025" $37.00
3680 Yam 1200/1300 PV Exhaust outer cover #1 $8.00
3720 Yam 1200/1300 PV Crank seal kit $24.00
4430 Yam 1100/1200 Reed to cases(2 req'd) $7
4550 Yam 1100 exhaust manifold $12
4455 Yam 1100/1200 Muffler Dampener #1 $6
4460 Yam 1100/1200 Head pipe $6
4470 Yam 1100/1200 Exhaust outer cover $7
4480 Yam 1100/1200 Exhaust Inner cover $9
4500 Yam 1100/1200 Head cover shell $10
4505 Yam 1100/1200 Flywheel cover $10
2525 Yam 1100/1200 Crank seal kit $25
4510 Yam 1100/1200 Oil pump Gasket $2
4600 Yam 1200 Stainless Steel .025" $36
4615 Yam 1200 Base gasket $10
4630 Yam 1200 Flame arrestor cover $6
KAWASAKI
5250 Kaw 440/550 Intake(2req'd) $2.00
5335 Kaw 44/550 crank shaft seal kit(3 seals) - $18.00
5280 Kaw 440/550(pre 91) Exhaust manifold $6.50
5400 Kaw 550(Pre 91') Ultimate synthetic fiber head gasket $22
5430 Kaw 440/550 cylinder base gasket - $5
5460 Kaw 96-90 carb base 44mm $1.50
5640 Kaw 550 91' or newer-reed/intake - $2.50
5800 Kaw 650 Stainless Steel head gasket .010" - $23.00
5850 Kaw 650 cylinder base gasket - $6.00
5860 Kaw 650 Reed $2.50
5880 Kaw 650 exhaust manifold $7
5890 Kaw 650 Head Pipe 44mm $7
5900 Kaw 650 Head pipe 46mm - $7
7000 Kaw 750 Stainless Steel head gasket(.010") - $24
7001 Kaw 800 SXR Stainless Steel head gasket(.010") - $33
7040 Kaw 750/800 Base $7
7040.020 Kaw 750/800 Base .020 $10.00
7040.030 Kaw 750/800 Base .030 $10.00
7040.040 Kaw 750/800 Base .040 $17.00
7040.050 Kaw 750/800 Base .060 $17.00
7042 Kaw 800 SXR cyl. base - $6
7050 Kaw 750/800 Reed (4 req'd for single carb model) - $3
7060 Kaw 750 SXI/PRO keihin 40mm OEM carb base no locator holes - $2
7065 Kaw 750 SXI/1100 keihin 40mm OEM carb base with locator pin holes - $2
7067 Kaw SX-R 800 40mm carb base(4 req'd) $2.00
7070 Kaw 750 Exhaust manifold(2reqd) $3.50
7080 Kaw 750 head pipe(all models) $6.50
7090 Kaw 750 upper front muffler - $6.50
7430 Kaw 750 Intake to cases(2 req'd for dual carb model, also req'd are 2 7050) $3.50
7075 Kaw SX-R 800 exhaust manifold to cyl(2 req'd) $4
8050 Kaw 750/SXR800 flywheel cover GASKET(Thicker gasket for timing advance kit or to get rid of O-ring) - $10
5935 Kaw 650/750/800 Crank shaft seal kit(3 seals) - $33
7650 Kaw 1100 exhaust manifold(3 req'd) - $6
7660 Kaw 1100 head pipe - $7.50
I make all Kaw 1100 gaskets, just ask!
SEA-DOO
6025 Seadoo 720 Base $7
6035 Seadoo 785/800 Base $7
6082 Seadoo 785/800 Exhaust $8
6150 Seadoo 720 Headpipe $7
6155 Seadoo 785/800 Headpipe $8
6618 Seadoo 785/800 Power Valve $3.50
6732 Seadoo 951 Base (98+) $9
6740 Seadoo 50 MM Carb $3.50
MIKUNI SBN, BN, AND KEIHIN CARB BASE GASKETS
5030 Mikuni 38MM black fiber Carb base $1.50 or 10ea. for $12
5460 Mikuni 44MM black fiber Carb base $1.50 or 10ea. for $12
9245 Mikuni 46MM Black fiber carb base $2.00
9230 Mikuni 38MM ultimate green Carb base w/metal mesh(reusable) $2.75
9240 Mikuni 44MM ultimate green Carb base w/metal mesh(reusable) $2.75
9250 Mikuni 46MM ultimate green Carb base w/metal mesh(reusable) $2.75
9252 Mikuni 48MM ultimate green Carb base w/metal mesh(reusable) $2.75
9257 Mikuni 50MM ultimate green Carb base w/metal mesh(reusable) $2.75
We are adding new dies all the time, so this list may not be completely current, so please message because we are striving to have all gaskets for all makes/models/
Please PM me with your questions and needs, and shipping is always a flat $6 for USPS PRIORITY(2-3 day).
You can also go USPS Parcel post(2-9 days) for $3.
Thank you and you will not be disappointed! MADE IN USA!!!
YAMAHA
KAWASAKI
SEA-DOO
