I would like to add, in my opinion, more important than engine weight, is horsepower to weight ratio of each.
More important than that to freestyle, is powerplant size and compactness and placement in the boat.
Just my worthless pennies.
Brian
Compactness: that is strike 1 against 66E
Power/weight: 66E should be about 150hp in a drypipe freestyle setup, don't have all the weight specs but it will give you about 1.5hp/lb
If the others are tuned to the same bmep, they should be at about 1.65/lb
Exhaust outlet at flange size: Kawi gets strike 1, 66E is good, 62T can be opened up so it gets a 50/50 but still depends on cc's
Reedcages: 66E is king, the others start lacking at around 900cc
What is the smallest bore setup for the yami's?
Price on Kawi billet 4mm crank?
Price on 12 and 16mm Yami cranks(are they billet?)?
Am a bit worried about piston speed on the 16mm, what do they rev to?
Prices on cases?
Anyone got a bedplate to fit 62T into kawi hull?
