ceramic coating pistons
cambo au
TRYING TO LEARN
AUSTRALIA
i just sent my new b pipe manifold to a performance coatings place to get it coated witch got me thinking when i was playing around with cars guys use to get the tops of there pistons ceramic coated has any one done this on a ski ? If so did it help or what did you find?
Don 79 TA
Still Fat....
i have my pistons thermal coated and side coated too
to me it's worth it for a 2cycle, especially if you are going to play on the edge of detonation
i did it more for protection porposes
it's sorta cheap insurance
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Good for closed course racing...not needed for freestyle as you want some piston heat to promote complete combustion burn with richer jetting set-ups that freestyle motors use.
freestylegeek
waiting...
Grand Rapids, MI
OK, where was that advice when I had my pistons coated? :frown:
Although, now that I am no longer using my top screw on my 'b' pipe, I'm not dripping water onto the pistons, so I guess it's overkill...
I'll be curious to see what a difference it made on this motor when I tear it down.
Jr.
Standing Tall
Staff member
Hot-Lanta
Differance in opinion on motor builders? Probably. I personaly like the coating. Overkill?? Maybe. Chuck is correct that it benifits high rpm race motors, But a lot of FS riders are running relatively high compression, with low grade fuels. & the timing is always an issue, As is correct tuning. The motors devolop power using BTU output....... HEAT!! anyway to help prevent a deto problem & keep the motor alive is always a good thing.
I'm not disreguarding Chucks statements. He has a wealth of knowlage.
Just a differant way to build a mousetrap! :cool2:
Ski ya, Paul
freestylegeek
waiting...
Grand Rapids, MI
The top screw, when open at idle, has a tendancy to drip water into the exhaust ports. Granted,it's maybe only a drop every 5 or so revolutions, but it's still getting in there. My headpipe is an ex-raceer pipe that had the top screw frozen shut. I re-drilled farther back, but at a shallower angle, and when THAT screw was open it basically streamed into the exhaust.
Without a coated piston, the water contacting the piston can cool it very quickly, shrinking it, and allowing it to slap and scrape those gorgeous Lamey sleeves. Something no-one here wants. :smile:
SUPERTUNE
Race Gas Rules
Clearwater Fl.
I'm not saying don't do it...I just spend the $$ in other places!! LIKE ON A VERY GOOD IGNITION! Word to the wise...timing curves MAKE horsepower.
SkiDaddy
Just Havin' Fun!
Orange City, FL
FWIW, and if memory serves, I noticed on Magoos boat at the January freeride he has water injection right into the cylinder's exhaust ports....:bigeyes:
Jr.
Standing Tall
Staff member
Hot-Lanta
Shhhhh............ You are not 100% correct, But................:cool2:
I totaly agree, timing is everything!!!
