how to tell 08 poles from earlier ones?
QJS
X-
GONE
You need to measure the distance from where the cable locates to where it attaches to the steering plate, it will be about an inch shorter on the 08.
Chris.
Motorheads5
Livin the generation gap
ketchikan alaska
I just went through the same thing and was told the steering stop was casted in to the 08 and up. The 08 and older is bolt on steering stop pretty simple.
ItsRixter
SoCal Wav Jumping shiznit
Sunny Diego
yup...that pic you have is an 08 or 09 pole (which suck). The 96-07 have a nut on the bottom holding the steering stop. the 08-10 are the same as a FX1 pole
