Waste Land
Non Multa Sed Multum
- Florence, AL
Here is your basic Mikuni Carb.
Find the rear of the carb marked with a R. Remove the 4 Phillip/Flat Head Screws
Remove the two phillips head screws holding in the jet cover. Be carefull, these are very soft metal and will strip EASY.
Using a flat head screw driver remove the jets from the carb.
Screw new jets in snug not tightened a lot and proceed to put the carb back together.
