650 SJ budget build and defoam
jetski9010
Team RTYD
Lancaster PA
My friend picked up a 1990 650 SJ thats is bone stock in overall in good shape. He has never rode a stand up before but I wanted to make sure he is not going to out grow the ski in a month and be stuck with it the rest of the summer so I am doing some mods to it to at least last him his first year I hope.
Malone footholds
Defoam with no foam
home porting on the 650 motor/cases
shaving stock head
aftermarket pipe
Hooker prop
jetski9010
Team RTYD
Lancaster PA
I couldnt find anyone local that had the plugs I was looking for. Everyone packed up their boat supplies for the winter I guess. I ordered some online that should be here in a few days I hope.
SXIPro
JM781 Big Bore
Looking good. Seal that puppy up good at every pipe/fitting/hose, etc. and bond line of course. Also a good time to throw in a bilge pump or two now that you yanked the motor.
jetski9010
Team RTYD
Lancaster PA
Yea going to put a 2nd layer of 5200 on everything before I seal up the back to make sure its all good. I was going to put a bilge in there that way I can also run dual cooling but I am trying to figure out if its worth it to spend his money on a bildge setup or put the money into other mods first.
jetski9010
Team RTYD
Lancaster PA
started pulling the motor apart. Cylinders look good. piston wash on the front cylinder looked a little weak but over all the engine looks like its in good shape. Got the flywheel and head ready to send out to be shaved down.
jetski9010
Team RTYD
Lancaster PA
Pics before porting. Also starting filling the cases with epoxy.
jetski9010
Team RTYD
Lancaster PA
tray glassed back together and footholds installed. Also installed the drain plugs.
jetski9010
Team RTYD
Lancaster PA
pics of the porting in progress. I got the one exhaust port done I still need to polish it. Going to do the other exhaust port then match the transfers then going to move on to the cases.
jap7t8
Spring Fever...
St. Louis
Dumb question...is "porting" simply making the ports larger or what?
jetski9010
Team RTYD
Lancaster PA
In a way yes but there is a lot more to it then that. I real port job will factor in everything about the motor like what time which port opens and for how long and how much air gets in and were that air is directed. Doing all of that is a black art skill that very few are good and doing. What I am doing here is just called "home porting". If you want to learn more about it check this out. http://www.x-h2o.com/threads/1540&highlight=home+porting
jetski9010
Team RTYD
Lancaster PA
Did some work on the pump today. Setup for dual cooling and installed hooker prop.
jetski9010
Team RTYD
Lancaster PA
ported the cases tonight
