How I do a scupper
SuperJETT
none
I've had the exact same scupper valve for 5 years now, same rubber flap, etc. It barely leaks, has always worked well, etc.
In the process of refoaming, I put a new tube in, used 2 street 45's to offset the inlet to under the intermediate housing, and just redid the outlet like I always have.
This works well for me.
I seal the pvc pipe to the hull (used PL roof and flashing sealant this time around instead of 3M), let that set up, then grind the pipe so it's slightly recessed from the outside of the hull, then run a bead of 3M all the way around it, then screw the ring on with a CD underneath. The CD gives me a smooth finish on the 3M, and the 3M stays flexible so the rubber flap has a nice surface to seal against. The ring gives even pressure all the way around.
You have to cut holes in the CD for the screws to go through, plus I have to chop one side off to clear the HIN plate.
It's worked so far, and 5 years on the same flap tells me it's a good technique.
SuperJETT
none
Of course not. lol, after I take it off I have a nice perfectly smooth rubber (3M) surface for the scupper flap to seal against.
F
Freestyleriverrat
Guest
Thats my CD!!!!!! :banghead: :banghead:
:haha: JK
Tuscaloosa, AL
I just bought the install trim ring when I did mine............. I am on my second flap, but, may put my old one back in, (one with the carbon plate on it) the newer one leaks!
SuperJETT
none
I was so busy getting it ready to run that i didn't take pics, but will. Just imagine a smooth surface that is all 3M.
beachedflunkey
wavejunkies
Virginia Beach
Great idea!
Sorry for the repitition, but just to be clear... you sealed the pvc in place, cut the excess, then sanded (How did you grind it?) down around the rim (1/8"?), applied 3m, screwed on the cd, let it cure, removed the cd (3m doesn't stick?), and trimmed excess glue?
SuperJETT
none
Pretty much, yes.
I ground the pvc down with my Dremel so it's below the level of the hull, then the 3M is what builds it back out so it's flush. The PVC is sealed from the inside since i had the foam/footholds out anyway, and the 3M is an extra seal on the outside.
