- Annapolis, Maryland
melted two pipe couplers.
Late last season i bought a WB1. Last year i only ran it once to make sure that it was running ok. which it was. Over the winter i stripped it down and cleaned up the entire thing. At that time i set it up for dual cooling. The dual cooling is 1 to the engine and one only for the exhaust. I set it but tapping into the pump into the bottom of the head, out the top of the head, straight line to pisser, T to a flow control into the stinger. I have great flow out the pisser. It actually is warm and may not even be near 120 degrees since i can keep my hand in the flow of the water. I would of thought it was that i had a screw cutting off the flow but i got the flow.
now the past two (only been out twice) rides i have melted and ripped the coupler off the head pipe to the chamber. The first time i thought it was just old and rotted out. The second time i noticed the entire exhaust to be extremely got. water box out and everything. also before i ripped the coupler i was getting the most heat around the coupler area because it was melting the paint on the pipe the most around there.
any ideas as to what to do or check.
i even disconneted the flow control, pulled the ball and spring for more flow there. while doing that was able to blow air back through the entire system making bubbles come out the pump.
help any ideas.
help any ideas.
