This is a newly built 62t/61x 718cc freestyle motor ported and built by Blue/JetManiac. It is designed to offer the most freestyle low end power for the least money.
These motors rip! They offer the most freestyle power for your dollar.
It is designed to use stock dual 38mm carb setup and jets, springs, and carb tuning specs included. This package offers a no headache install that is easy to tune and rip. Motor also good with dual a/m Mikuni 44 carbs for more power with a full on build.
62t matching cases- complete freestyle ported and epoxied intake, top, and stator area.
61x cylinder- freestyle ported, exhaust area/head decked for best seal to ADA head
New bore and finish hone to 82mm or larger
New Pro-X top end with new pistons, rings, and wrist pin bearings
New Rebuilt OEM Crankshaft by SBT with all new rods and bearings, then trued and welded, includes 1 year no fault warranty
New engine internal gaskets
New OEM crank seals
Sandblasted and then bead blasted, painted and baked on beautiful black finish
New carb jets and springs for oem 38's included, and carb tuning specs included
It is designed to use stock dual 38mm carb setup and jets, springs, and carb tuning specs included. This package offers a no headache install and easy tuning ripper.
ADA head and complete intake/carb setup package available.
*We can also rebuild your motor into one like this or trade-in your core motor (crank, cases, cylinder) with usable parts for approx. 400. credit off this motor.
Freestyle Ported Short block $2089.
*No core motor needed.
New OEM crank seals
