- South Florida
How accurate are the LED readings on a dual channed brain when checking the static timing?
1st cylinder is lighting up at 28 degrees advance but the 2nd cylinder is lighting up at 31 degrees. I seem to remember reading about some bad pickup plates out there that are not at 180 degrees. Is that probably my problem? Or is the LED not all that accurate and I should check the timing with a timing light and not worry about it?
