JetManiac MASTER PARTS LIST
Freestyle and Freeride Parts
JetManiac is your source for freeride parts- new, reconditioned or used oem and aftermarket parts.
We have parts for your freeride build whether you are building your first ski and need troubleshooting advice or a custom build parts package. We specialize in custom freeride builds parts and can help you with build parts and hardware or complete custom driveline packages.
We love to ride and are dedicated to your satisfaction! Professional service and support, packaging and quick shipping too! We also specialize in international orders and shipping.
Authorized Dealer for:
ADA, Blowsion, Cold Fusion, DASA, Xmetal / XScream, RRP, Skat Trak, Impros Hooker, Hot Products, PHP, Torrent pumps, Thrust Innovations, Solas, Pro-Tec, PUSH, etc.
Just click on your inbox in the upper right corner of your screen and click 'start a conversation' and enter JetManiac here on the X to place an order!
Tow strap kits, Billet bow eyes , Tow eyes and loops
Exhaust and Cooling Parts
Factory Pipe Bpipe , PowerFactor pipe, PFP, TNT, RRP pipes
Bpipe gaskets, SS Headpipe bolts, JetWorks FCV -Flow Control Valves, Waterline fittings, Pissers
Engine Rebuild Parts
Rebuilt Cranks, ProX and Wiseco pistons, Gaskets, Crank Seals
CLICK here >> http://www.x-h2o.com/index.php?threads/engine-rebuild-parts-rebuilt-cranks-prox-wiseco-pistons-gaskets-crank-seals-etc.142081/
JetManiac Ported Motors
Ported 62t twin carb motor
CLICK here >> http://www.x-h2o.com/index.php?threads/jetmaniac-62t-61x-freestyle-ported-motor-1725.77233/
Big Bore ported BB781 motor
CLICK here >> http://www.x-h2o.com/index.php?threads/big-bore-781-freestyle-ported-jetmaniac-blue-motor.94512/
JetManiac/Blue Ported Top End Kits
CLICK here >> http://www.x-h2o.com/index.php?threads/jetmaniac-blue-freestyle-ported-top-end-kit-650.106417/
Electrical Parts
Starter, Bendix, Lightened flywheels, Ebox parts, Ignition Coils, CDI, Starter Solenoids, Start/Stop Switches, and Lanyards
CLICK here >> http://www.x-h2o.com/index.php?threads/jm-electrical-parts-ebox-starter-bendix-flywheel-stator-start-stop-solenoid-cdi-msd.146781/
Carb, Intake Parts
Rebuild Kits, Mikuni jets and parts, Popoff carb tester, Fuel Filters, Primer kits and parts, Flame Arrestors and Adapters- Prok and Tau Ceti V-Force 2 or 3 Reeds/Cages Yamaha 62t/64x Boyesen and Carbon Tech Reeds
CLICK here >> http://www.x-h2o.com/index.php?threads/jm-fuel-shop-carbs-carb-parts-primers-filters-intake-reeds.144171/
Pump Parts Shop
Driveshafts,MAG/OEM pump,Props,Wear Rings, Pump Shoe, Intake Grate, parts
Skat Trak MAG pumps Impros HOOKER and Skat Trak Impellers
CLICK here >> http://www.x-h2o.com/index.php?threads/pump-parts-driveshafts-mag-oem-pump-props-wear-rings-pump-shoe-intake-grate-parts.142220/
Trim Systems and Trim parts
Thrust , RRP , XMetal / XScream
CLICK here >> http://www.x-h2o.com/index.php?threads/trim-systems-from-jetmaniac-thrust-and-xmetal.141581/
Midshafts and parts
CLICK here >> http://www.x-h2o.com/index.php?threads/midshaft-shop-intermed-shafts-only-or-complete-for-superjets-new-used-rebuilt.123139/
Handlepole and Steering parts
Poles , Pole spring/bushings, Steering, Handlebars, Grips, Throttle Lever
CLICK here >> http://www.x-h2o.com/index.php?threads/handlepole-steering-throttle-grips-shop-ada-rrp-cold-fusion-odi.125011/
Steering and Throttle Cables, parts
Superjet, Waveblaster, FX-1, Kawasaki Cables, Steering Cable Installation Kits
CLICK here >> http://www.x-h2o.com/index.php?threads/steering-and-throttle-cables-superjet-waveblaster-fx1-kawasaki-cables.87804/
Motor Mounts Kenney Keepers
CLICK here >> http://www.x-h2o.com/index.php?threads/motor-mounts-shims-kenney-keepers-mount-hardware.193719/
MORE PARTS IN POST 2 BELOW
Hood strap kit, Hood Hooks, Hood latches, Hood parts, Hood seal, Limiting rope
Hood strap kits, Hood Hooks, Hood latches, Hood parts, Hood seals, Limiting rope kits
JetManiac's Hood Parts Shop Ratcheting Hood Strap Kit Ratcheting hood strap kit $49.95 sale 43.95 -replaces stock latch or extra security and use with stock hood latch -includes complete SS mounting hardware(bolts, washers, and nylock nuts) for both ratchet and straps. These 1"...
www.x-h2o.com
JetManiac's towing shop -Tow strap kits, Billet bow eyes , Tow eyes and loops
Tow strap carabiner kit Tow strap kit - HD stainless carabiners for towing $20.95/set Marine grade stainless with all stainless design, even the lever catch, no hinky steel pins to rust on these burly carabiners. 15 years of towing experience by JM customers with these bad boys. These are...
www.x-h2o.com
JetManiac Exhaust and Cooling Shop: Factory Pipe Bpipe Parts, Pissers, Hoses, Waterline, fittings
JetManiac's Exhaust and Cooling parts shop Exhaust gaskets U.S. made high quality SS reinforced gaskets Factory Pipe headpipe gasket $9.95/ea or 3 for 9.49/ea (Stock FP headpipe gasket 47mm) Factory Pipe Big Bore headpipe gasket $10.95/ea or 3 for 9.95/ea JetManiac has big bore headpipe...
www.x-h2o.com
Electrical Parts
Carb, Intake Parts
Pump Parts Shop
Midshafts and parts
