Super Jet Superjet 650 Stock jetting and Carb setting?
N
newbb
Guest
Anyone know what the original carb settings are on a 1992 yamaha Superjet 650?
Stock exhaust, stock F/A, stock everything.
Low Jet = ?
High Jet = ?
Needle/seat and spring = ?
Low speed adjuster turns out from close?
High speed adjuster turns out from close?
Thank you in advance for any help?
Good to keep this alive. Thanks for the screw settings haha.. just happened to be looking for those.
Did a search for the carb jets and oem SN from 90 thru 93 is:
Pilot: 120
Main: 115
N/S 1.5 with ?? Spring
Additionally this varies to the LX with the lower compression head:
Pilot: 115
Main: 115
N/S 1.5 with ?? spring
That info is from Cycle Parts Nation and their parts diagrams. The carb has the pilot jet mislabeled. Follow the diagram, the larger main jet is in the upper right, item 16 and the pilot is in the center, item 19. Hope that makes sense, if you go search and check the parts list you'll see what I mean.
