- CT
The way Yamaha should have made the SJ!!!!
Brotha-Bruce picked up a 08 SJ that had 4 or 5 tanks of gas through it. We rolled it right in the shop and started to cut it up!
Now we are big fixed steer guys so a hood from Tom21 was first on the list. Bruce also wanted the tray like how shawnNJ did his with full lenght foot holds. So here is the list of the build.
08 hull
Tom21 hood
UMI
wide tray (thin rails)
moved rear pipe down
factory pipe
ADA head
ATP water box (with a few changes to it)
reinforced the hull
JSS Coil
And a ton of small things no one will ever know.
Cleaned up wired
Welded 90 bilge fillting
dual tank breathers
and the list goes on
08 hull
Tom21 hood
UMI
factory pipe
ADA head
reinforced the hull
JSS Coil
Cleaned up wired
dual tank breathers
